Alexm930's Avatar
Side Marker Bulb Replacement
Question for the brain trust here. On RoW cars, how does one remove the lens or fixture from front fender to replace a bulb? Searching here led to no results. I am speaking of the little square markers on the front fender found on Euro models only. See photo. Thank you in advance.
Speedlimits are for the guidance of wise-men & the obedience of FOOLS!
Old 09-13-2016, 12:26 PM
Alexm930's Avatar
40 views & nobody???
Old 09-14-2016, 05:42 AM
Oh Haha's Avatar
The housings have small tabs that hold them against the inner fender. I'm not positive on the bulb but I think they are the same as used in the dash. It should be evident once you remove the housing.
Pacific Blue
Wayne
Old 09-14-2016, 06:29 AM
proffighter's Avatar
A pic says more than 1000...
Watch and think
Roland
930 Turbo '81 Too many modifications to list
Old 09-15-2016, 03:43 AM
Ok if not clear:
Push 1 and lift around 2 up to about 45°, then pull the whole thing out.
Roland
Old 09-15-2016, 03:48 AM
GeorgeM's Avatar
The bulb holder can be pulled out from behind without removing the housing from the fender.
Just pull on it and it'll slide out.
If you remove the housing, be careful when squeezing that tab circled in green. It may be brittle and break. New Hella units are readily available and only about $7 a piece.
If you have an older car with an electric antenna, you may have to remove it (or rather just drop it down out of the way) to get to the passenger side light.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
Old 09-15-2016, 06:18 AM
Alexm930's Avatar
Thumbs up
Thanks Profighter & GeorgeM. I got it now.
Old 09-15-2016, 07:45 PM
