Ghostbusters to the rescue!
I put in a call to the Ghostbusters. I got out the proton pack and went to work my 911
Actually I swapped out both of the crank sensors and the head temperature sensor "while I was in there." Since the head temp sensor uses the same grommet and is connected to the engine harness in the same spot it is pretty easy to just do all three. With some trepidation and for sure not 100% confidence I fired it up and it ran perfect but it always has when cold. I then went for a drive, but I stayed within a couple of miles of my house. I got it up to 180 degrees and had no problems. I got home and ate lunch. Then I went for a 30 minute drive. It was only 70 degrees outside so the engine will not get above 185 degrees. It ran flawlessly. As this point I THINK it is cured. All I can figure is one or both of the flywheel sensors was flaky. Since it is just a one hour process to actually swap them I am annoyed at myself I was sure they were OK. They tested out fine but I never could test them when they were hot enough to show a fault. The head temp sensor was likely OK, but it was a for sure easy swap while the other sensors were being swapped. If it starts having issues again I will revive this thread. If not I will consider the car cured. If your find this thread while researching problems, don't assume it is for sure the crank sensors, but for sure they are a source of a seeming poltergeist. I celebrated the fix with my favorite beer. Darn good beer! ![]()
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Alright Glen!
Dunk them in hot water or hot oil to get them HOT and test them. Just to see
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
A mildly hesitant 'congratulations!' while you continue to test and review this hopeful success!
Let's hope the poltergeist has packed up and moved onto more fertile ground, like some Italian car where they can be more entertaining. Do you have a link or a recommendation on the speed sensor and CHT? Just making sure I get the right thing if this is my next step.
Porsche M491 Coupe '85 Porsche 997 GTS '12 Porsche 911 SC, '82 Porsche 914-6, '70 Audi S4 Avant V8 manual, '05 Last edited by AHudson; 10-11-2016 at 04:24 AM.. |
I bought the speed sensors right here on Pelican. Part number 12-14-1-708-619-M14 and get two of them.
They are the BMW part but they are two of them for the price of one 911 sensor. That Porsche tax is silly in this situation. The head sensor one is the Bosch part Pelican sells part number 930-606-915-00-M14. The new grommet in on the head sensor so if the old grommet is toast you need the new head temp sensor anyway. As I said, while you are in there...... Those sensors go in a certain order. It is important or really vital that you get them back on in the same order. Put a dob of paint on the top connection and two dobs of paint on the bottom sensor before you pull them out of the engine compartment. Put the same marking of paint on the new sensors so you KNOW what position they plug into the engine harness. Today the local weather is forecast to be mid 80s. That is hot enough to get the engine up to full heat soak. I drove the car to work today just to test it at lunch time. It is like having a dog that bit you once. I want to pet it again but it will have to earn the full trust before I relax. I drove it over 5,500 miles just back in June and it ran perfectly the entire trip. I am just so glad it waited until a few months after that trip to have issues. I will hit the old sensors with my heat gun and get them to 200-250 degrees and see if the ohms read the same this weekend if I have time. I will do that and report back whenever I get to it.
Dave |
Caveman Hammer Mechanic
He sent it to Steve Wong for "testing and repair". Seems that Steve found a component on the board that was out of spec and replaced it. Unless you work on FAA stuff, rebuild is a very generic concept ranging from Metric Mechanics to JWE. Not sure why you are picking at this...... Nice that the fix was relatively simple!
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 10-11-2016 at 07:38 AM.. |
out of spec and replaced it", right? Could have bought a lot of cases of Erdinger Beer!
Dave |
It was well worth the rebuild. Whether you use Ingo or Steve, these guys are very reputable and have nothing to gain by selling you unnecessary work. 3.2 boxes are failing right and left lately, so the OP ultimately saved himself another breakdown further down the road. I say it was money well spent.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
I just received a DME from a customer to be inspected and tested. This DME is missing all 4 screws for the heat sinks on the lower board! DME was working but the standoffs are completely loose and rattling around inside the DME and the owner had no idea! You just never know what you'll find when looking at these DMEs. I had another one a few years back that had same 4 screws missing and the heat standoffs as well! Often these DMEs have aftermarket chips and the owners don't know. Is it worth sending the DME for inspection and eval by a professional, you decide based on your ability.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Do we know for certain that the original poster was inappropriately sold DME services as described above? The entire thread seems to indicate that the rebuild services that were provided were appropriate. If this is the case, the above post seems inappropriate. Please let me know if I am reading this thread incorrectly.
I would consider rebuilding the DME preventive maintenance a good idea. I'm thinking of having my DME and two cdis redone since they're so old. Not worth breaking down and being stranded.No matter the cost peace of mind is the issue.
When all was said and done with my car, it appears as if I had two issues. A hot running issue appears to have been caused by the cylinder head temp sensor. However, the hot start/no start issue was a bad connection in the wire from the DME relay to the fuel pump.
Your DME wire runs to the fuel pump fuse, and from there to the fuel pump. Check and verify that the screws on the fuse block are tight, and that the fuse is sound and the contacts are clean. A lot of juice runs through that circuit to the pump, and these connections are getting on in years. It's just a PM thing. I would also just like to say here that both Sal and Ingo spent time helping me get my car running, and they spend a lot of time here helping people for free. These guys deserve thanks, and they deserve your business. Ingo tested my DME, and he flat out told me that it worked, but that it looked like hell in there. Well, I saw it, and I knew it was true, so I let him go over it for me. Later, when I was having wiring issues with my 3.2 conversion, Sal went over the wiring with me, and sent me diagrams and a checklist. He spent a lit of time on the phone with me. In the future when I do upgrades, I am going to remember that. And I think we know that Steve W has a reputation for being a straight shooter as well. These guys have made major contributions to our community, and for many of us, they are the reason why our cars run today. Last edited by DanielDudley; 10-11-2016 at 03:12 PM.. |
Here's what should've been done: Quote:
Dave Last edited by mysocal911; 10-11-2016 at 04:24 PM.. |
They're called mistakes everyone makes them. Dave
I did read the entire thread. The DME was not incorrectly diagnosed nor was it repaired by a rebuilder that makes repairs that are unnecessary. Two posts in this thread paint an unfair picture of the rebuilder.
Yes, that's true but unfortunate. As has been posted, another rebuilder takes an alternate approach
which can potentially benefit the customer in the long run. Bottom Line: The "shotgun approach" to troubleshooting can be very costly in time and money!
Dave |
Undocumented User
There are many times when there just isn't ONE problem to the cars, some time problems lead to other problems or we're left diagnosing two issues that when combined really throw people off and you fix one and still have to contend with the other. There's no proof that the ECU repair wasn't warranted so why make the stink about it especially if the owner is okay with paying for his peace of mind. I've added some of the details here to my no start knowledge base the next time I come across it, thank you very much. |
1983 RHD SC 3.0 1994 RHD E31 850 CSi |
I have no doubt whatsoever that I had a dual issue. The ignition circuit on the DME was an issue. Steve fixed that and I have no problems with his services. The two flywheel sensors and the head temp sensor were a package fix. Personally I can't imagine doing the two sensors and not doing the head temp sensor, or the head temp sensor and not the two crank sensors. That is just my opinion, yours may different.
This weekend it will be in the mid 80s and I plan on a one hour drive and another test of the system. I do have a loaner DME with me that I have not used. It is just there as a belts and suspender backup. I really don't expect to need it. It is a 31 year old car with 166,000 miles on it. I plan to drive it to Spokane next summer. Another long road trip and part of my quest to drive my Porsche in all the lower 48 states. Canada is already been checked off the list. If you have never had your DME checked out, I would recommend you pick the guy you trust the most and send it in to be double checked. It will fail at some point. I have built some Heatkits in the past but I don't have the skills or the equipment or knowledge to really know what I am doing on an inspection or any repairs for a DME. I do know my limits.
