What is the difference between 911 & 930 trailing arms?
Uuge difference in price is why I ask.
gearhead
Length and geometry.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Would there be benefits in using them on an sc or carrera body car?
No.
Max Sluiter
you can't
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
It won't fit unless you change the torsion bar tube. If you have access to a Celette, you can modify/fabricate the trailing arm mounts to suit.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
and different position of brake caliper. 930 after hub, 911 before.
Roland 930 Turbo '81 Too many modifications to list |
about $1000 dollars
