-   -   Just bought UTCIS controller from unwired tools (http://forums.pelicanparts.com/porsche-911-technical-forum/929120-just-bought-utcis-controller-unwired-tools.html)
JohnJL 09-17-2016 06:26 AM
Originally Posted by tobluforu (Post 9284561)
I love it when people on this board question the cost of things, cracks me up. Hey, I just installed a some ssi's. Sweet, how much did that coast ya, well its cost...
I believe my question was a factual one, no judgement.
JohnJL 09-17-2016 06:30 AM
Am I allowed to ask why its called UNWIRED tools when it needs a cable?
tobluforu 09-17-2016 06:50 AM
I realize that, but its just funny as Porsche parts are a joke and we all pretty much know that. I got lambasted when I thought Braid wheels were a joke in regards to price. Its all relative I guess.
gomezoneill 09-17-2016 07:53 AM
He was just pulling your leg John no need to take it personal.
SCadaddle 09-17-2016 08:22 AM
So what's the current "going rate" to have a professional shop rebuild an old WUR to factory specs? I would have to weigh that cost against this new approach.
gomezoneill 09-17-2016 08:34 AM
The point is this can be programed. One of the many benefits is the throttle response, as it will lower the control pressure to richen the fuel mixture so you wont go lean at higher engine reves. If you modify your engine you can program the unit to match the specs you desire.
Here is a link for a rebuilt 82 sc WUR. $420.00 + 300 core charge
rwest 09-17-2016 09:37 AM
I'm very interested as my car basically runs good, but just seems like something is a bit off- still need to chase a few suspected vacuum leaks.
Do you have any photos of it mounted and where you placed the controller?
RSBob 09-17-2016 10:01 AM
Be interested to hear a subjective opinion by a purchaser if throttle response can be dramatically improved. Lack thereof is my biggest beef. I know it is theoretically possible but want a seat of the pants review.
gomezoneill 09-17-2016 11:48 AM
Yes I'll put up a photo. It fits exactly where the WUR was.
KyMitch 09-17-2016 12:01 PM
This is pretty cool. But I've stripped the whole lambda system off my CIS. I guess for me it'd be almost like plugging a laptop up to a carburetor.. If a person needed to maintain the lambda for smog checks and such I can see it realy coming in handy then.
shbop 09-17-2016 02:19 PM
Caution: Bought a product from these guys a few years ago. Speed controller for an a/c fan. Was complete rubbish. Couldn't get any help from them after repeated tries. I would have no faith in their ability to supply any customer service, or a reputable product. Hope you have better luck.
JohnJL 09-17-2016 02:41 PM
I've never tried an aftermarket WUR/Idle valve with CIS, in each case I've wither kept the CIS in place and found working replacements in my box of spares, or converted over to Megasquirt/Adaptronic and used a ford idle valve. The ford idle stepper valved work great with aftermarket ECUs, can they not be adapted to work well with CIS?
Dave Kost 09-17-2016 04:52 PM
Under $ 250 no core charge - 1983 SC.
targa44 09-17-2016 11:35 PM
Yes - how are you determining the right AFR through the rpm range? Do you have an AFR gauge installed off of a wideband sensor or do you plan to go to a dyno to set it up?
gomezoneill 09-18-2016 05:31 AM
Wideband afr
rwest 09-18-2016 11:16 AM
Does it actually allow you to change the control pressure based on RPM?
I do see that it has its own temp sensors which should be more accurate than the heater that the original has.
spuggy 09-23-2016 12:47 PM
Originally Posted by gomezoneill (Post 9282806)
I purchased a digital controller (basically a wur) from Steve at un wired tools
Seriously? They're still around? There's at least half a dozen folks on the 930 forum who took unusable/non-working units off their cars..
Including one guy who noticed his sprayed gasoline everywhere inside the case - when received new. I wouldn't fit one without checking it first.
I guess if you wait long enough, or change the market slightly, the internet serves up a new market of folks who've never heard of you to step up and give you money.
and he has been fantastic to deal with
Yes, he does seem that way - right up until he volunteers that given that his unit clearly doesn't work acceptably despite his suggestions to fix what he called "ringing" (the RPM sensor said my 930 idled at 1800 and that I hit 8000 RPM during a leisurely commute to work) and tells you to send it back for a free upgrade to the latest revision they're just finishing up.
And then you'll never hear from him again. No replacement unit. No repaired unit. No refund. No replies to the next 30 emails and 50 phone calls.
8 years later, I'm still out $500 - for a unit that showed some promise, but never delivered what it was supposed to - because with the sensor issue, it'd have needed to have been mappable to 15,000 RPM, and it wasn't...
gomezoneill 09-23-2016 02:50 PM
Sorry to hear that. When was the last time you tried to contact Steve? He replies to my emails the same day. My laptop wouldn't load the software (win 10) He sent me a Ibm lap top with the soft ware loaded for 100 dollars. They have improved the original with a frequency valve instead of a stepper motor.
Do want me to contact him and see if he'll make things right for you? I'm using it on a 82sc not a turbo so it's a different application.
If you used paypal or a credit card you should've been able to get a refund.
shbop 09-23-2016 04:31 PM
Same experience I had.
gomezoneill 09-23-2016 04:57 PM
Wow guy's my car runs great. Can't comment on your experience but I'm happy.
