low speed drivability (like creeping in traffic).
I suspect this is just the way these cars ('86 3.2, 75k miles) are, but I'm wondering if there's a way to improve things.
If I'm in first gear, as in a line of cars creeping up to a stop sign or light, and roll on and off the gas, the car bucks something fierce. The only way to drive it smoothly in these cases is to push the clutch in. This coupled with the fact that my first gear synchros are useless makes life difficult. The car also shows the behavior in 2nd gear though it's not as bad and not really an issue.
By contrast, my new daily driver can literally be driven in first gear, with the clutch out, on idle up a hill with no bucking. I fully realize it's not valid to compare cars made 30 years apart from each other, but any words of wisdom are appreciated.
1986 911 Carrera Coupe
2016 VW Golf R
2008 Toyota Highlander (given to kid)
2021 Kia Telluride
2020 BMW R1250RS
Old 09-14-2016, 07:16 AM
My 86 doesn't act like this. I can creep up to lights with no problem. I would start looking at ignition and fuel systems to see what might be amiss.
Old 09-14-2016, 07:21 AM
Good to know it's not normal at least.
I've had the car for 5 years or so and in that time, I've replaced the plugs, wires, cap and rotor. The coil is original as far as I know. However, if it is an ignition problem, wouldn't it generally break down either under hard acceleration and/or damp conditions?
2016 VW Golf R
2021 Kia Telluride
2020 BMW R1250RS
Old 09-14-2016, 07:30 AM
While driving to work this morning, I was thinking about this. I wonder if a sticky ICV could make the engine "hunt"? Also, I know that soft engine and transmission mounts and worn CV joints can amplify bucking or hunting and turn it into a real jerking motion.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 09-14-2016, 09:00 AM
I believe it's normal for these 3.2's. My '85 did it and to a lesser extent my '88 does it. On the '85, it was pretty well cured by installing a Steve Wong chip. The idle is set slightly higher if I recall, and I guess the engine management is changed by the chip. Haven't chipped the '88 as it doesn't seem to be as much of a problem as the '85 was although at really slow speeds yeah, it's there...
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 09-14-2016, 09:14 AM
kuba_kuba's Avatar
Interesting - increased bucking at low speed is the only negative from installing a Steve Wong chip on my '88 (and its not that bad)
'88 911 Targa
Old 09-14-2016, 09:22 AM
Mine does have a Steve Wong chip installed by the PO. I guess I could put the original chip back in to see what that does.
Speaking of Steve Wong, any idea if he'll update a previously purchased chip? I've considered doing a cat delete.
Also, RedCoupe, as far as the ICV, my car had the problem of the idle bouncing when it's hot. Cleaning the ICV heavily with carb cleaner made this a lot better but didn't seem to do much for the bucking. It does seem like a logical culprit though.
2016 VW Golf R
2021 Kia Telluride
2020 BMW R1250RS
Old 09-14-2016, 09:50 AM
Smoove1010
Smoove1010's Avatar
My car did this and also had a flat spot while cruising. I tackled this using all of the troubleshooting steps outlined in the numerous bucking and hunting threads, including checking the O2 sensor, cleaning and checking the ICV, checking for vacuum leaks, re-setting base idle, and checking/adjusting the track/wiper on the AFM. In my case I smoothed it all out when I discovered that a previous wrench had molested the AFM, apparently to lean out the air/fuel mix, probably to pass an emissions test:
AFM Mixture - Am I That Lean?
I can now loaf along at idle in first gear with no bucking, and the flat spot is gone. Acceleration from loafing is smooth and linear with no flat spots. Having said that, dealing with stop-and-go traffic driving a car with a manual trans is still no fun.
Good luck!
GK
1987 3.2 911 Cabriolet
Grand Prix White Exterior
Five Shades of Burgundy Interior
Old 09-14-2016, 10:22 AM
Fastest Hunk of Junk
For a car as civilized as a well-sorted 3.2, I think bucking (SW chip or no) is definitely indicative of a minor problem. Pre SW chip and post SW chip, mine never did that--it's a great, smooth "crawler".
I don't know if SW will update a chip for a second owner, but he definitely will (at cost) for an original purchaser of a chip.
-Brent
Old 09-14-2016, 10:29 AM
T77911S's Avatar
put the original chip back in and then check the AFM.
my brothers had problems like yours and I think that's what fixed his.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-14-2016, 10:38 AM
Still here
pmax's Avatar
Doesn't sound normal.
My 87 drives smoothly at low speeds.
Old 09-14-2016, 11:15 AM
It's not that it's not driving smoothly at slow speeds, it just seems like a bit of bucking at times when going slow in heavy traffic & you let up on the pedal. Feels more like slop in the driveline rather than an engine hesitation problem which is why I was surprised the Steve Wong chip had such a good effect on the '85.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 09-14-2016, 12:12 PM
My SC has done it, I thought it was considered uncommon but not rare. There has been discussions of the "bucking bronco" syndrome.
One discussion was the "hanging" drivetrain in relationship to the long throttle rod and/or clutch cable, that you can get a frequency where the drivetrain is actually shaking the rod, which makes the throttle flutter, which makes the drivetrain shake, which is a vicious cycle.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 09-14-2016, 12:24 PM
Bill Douglas's Avatar
My SC does it a little too. I just think of it as the car telling me it's not a commuter car, but a car that dreams of wide open spaces (and wide open throttle).
Plus first gear is far too high for crawling along in traffic. Too much riding the clutch and stop and start - Corolla time I call it.
Old 09-14-2016, 12:59 PM
Chain fence eating turbo
It bucks because the timing is too advanced. A Steve Wong chip should fix this. I can dial this in easily with my aftermarket EMS MegaSquirt.
Too much timing, buck city. Retard a few degrees, smooth running.
It's been called the "neighborhood creep".
Old 09-14-2016, 01:36 PM
My 83 build 3.2 also does this. I was going to have it set up to see if there are any problems.
Old 09-14-2016, 01:43 PM
Rescuer of old cars
Arne2's Avatar
I fixed mine by reverting to the stock chip. Much improved low speed driveability.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Jacksonville, Fl
Mine does it a bit (very mild) at really slow speeds, right before you feel like your about to stall. Honestly, I just avoid going that slow... :P
Alex
Jacksonville, Fl
'88 Carrera, Guards Red
Old 09-14-2016, 01:47 PM
It has a Steve Wong chip in it, and don't most aftermarket chips advance timing anyway?
2016 VW Golf R
2021 Kia Telluride
2020 BMW R1250RS
Old 09-14-2016, 03:04 PM
DanielDudley's Avatar
Your throttle position sensor has two switches in it, one for idle, and one for Wide Open Throttle.
You want that adjusted so that the idle switch is only activated at idle. Once you crack the throttle open, you want that switch off, so the engine can make its own determination of what is happening via the other sensors.
Old 09-14-2016, 03:36 PM
