Discseven's Avatar
Need help with Arduino code for digital AC config
EDIT: Collaboration established.
Am putting together Arduino components to sense temp & humidity and to serve as a thermostatic controller for 911 AC system.* Collected data will be fed to a 4x20 LCD. "Set Temp" will be controlled by a potentiometer with temp target displayed on LCD.
Hardware for this I can handle. Am looking for an Arduino sketch expert to help with the code.
* System: 2 temp & humidity sensors, 2 temp sensors, 1 Arduino Uno, 1 4x20 LCD, resistors and potentiometers as required.
Collected sensor data:
Cabin temp
Cabin humidity
Evaporator core temp
Duct temp
Exterior ambient
Exterior humidity
Set:
Target temp (with some hysteresis)
7 data points will be displayed: 2 items per line on 4x20 LCD. "Set Temp" on top line by itself.
If/Then = IF "Cabin temp" is =>2 degrees F compared to "Set Temp", THEN compressor & fan circuit is closed (AC is ON.) If "Cabin temp" =< "Set Temp"< THEN compressor & fan circuit is open (AC is OFF.)
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 09-24-2016, 10:03 AM
I have not idea, but a suggestion. If you do not get a reply here, you could try posting in the "off topic forum", there seems to be quite a few techies there.
Who, What, When, Where, Why and How.
Old 09-24-2016, 06:41 PM
Discseven's Avatar
^^^ Good idea.
Karl ~~~
Old 09-25-2016, 06:49 AM
Dr J's Avatar
I could do it and am local to you. Send me an email or PM. I have arduino and breadboard but would need the specific sensors you are using or we can even discuss which to get.
Check out my sig
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 09-25-2016, 08:05 AM
autojack's Avatar
I would suggest you ask on an electronics hobbyist forum, like www.hackaday.io. More people there will have Arduino experience.
Old 09-25-2016, 08:39 AM
Discseven's Avatar
Check out my sig
PM'd you Dr J. If I interpret correctly... your WUR is Arduino-driven. Damm technofine!
Karl ~~~
Old 09-26-2016, 06:01 AM
Discseven's Avatar
Thanks for link AJ.
Karl ~~~
Old 09-26-2016, 06:03 AM
Discseven's Avatar
Collaboration established 9.26.16
Karl ~~~
Old 09-26-2016, 10:17 AM
