911 carrera 3.2 (1985)
Just unbolted the front seat, but can't figure out how to unplug the electrical connector without damaging it.
Tips, tricks? Thank you ![]() Kees |
911T '72
You just pull it out.
Dennis Good drivers have dead flies on the side windows. (Walter Röhrl) |
Look at it from the back of the seat. If I remember right, the connector lifts up. You can pry it with a screwdriver once you're able to see it clearly.
I got totally stuck on this. I was able to get the cable unhooked, but there was a 2nd cable harness that was impossible to detach. In fact, I remember someone else mentioning his cables that were cut and re-connected with a different clip harness, for easier removal, which proved to me just how hard it is to disconnect the seat.
There are details here. Front seat removal. How do you disconnect the power cable ?
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 09-25-2016 at 03:06 PM.. |
Thank you all and especially Sugarwood (in my case there was only one cable).
After I removed the bracket (2 screws) it was a piece of cake. ![]() Kees. |
Thread Tools | |
Rate This Thread | |
