How do I determine which '74 I have?
I need to order a Momo steering wheel and hub for my new-to-me '74 911. Apparently there two hub options-- one for 7/74 and earlier and one for 8/74 and later. Does anyone know if there are visual cues to the stock wheel and/or hub to determine which I need?
Alternately, is there a way I can use my VIN to determine build month?
Thanks!
Old 09-28-2016, 11:35 AM
You could use the last 4 digits of the VIN to get a rough idea of build date, other clues would be the date stamp (which would at a guess be a couple of months before) on things like the spare wheel, back of the instrument cluster gauges etc.
I think the difference between the early and late steering wheel set up, is the length of the steering column, a good clue might be the covers which go around the steeering wheel hub. Early = say 6" depth to dash and later say 3" depth to dash. Something like that.
Post a picture
Old 09-28-2016, 11:43 AM
Good tip:
Old 09-28-2016, 12:05 PM
Old 09-28-2016, 12:06 PM
Thanks!
Look at the Certification sticker in the driver's side door jamb and you'll find both the VIN and the car's build date.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-28-2016, 12:23 PM
Thanks. That was easy. 7/74 it is...
Old 09-28-2016, 12:50 PM
One difference is the early hubs had the turn signal cancel bar integrated in them, while the later hubs had it as a separate piece that bolted on.
So, remove your wheel, and see if the turn signal cancel thingy is molded right into the hub, or bolted on. I wouldn't trust a date stamp for something like that, especially when you're right/on that cusp.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 09-28-2016, 01:09 PM
^ thanks for the buzzkill. I must admit I was a bit worried about that date myself, though.
I'm going to a friends shop to do the install, so taking the wheel of just to check on the signal cancel thingie. Maybe I'll order both hubs and return the one I don't need.
Which begs the question--will it be obvious which hub I need? They look quite similar in pics.
Old 09-28-2016, 03:09 PM
djpateman's Avatar
That would appear to be the 1974 to 1975 model year split.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 09-30-2016, 07:27 AM
The problem is that almost every picture of the Momo 230 or Momo 231 are showing the top, not the bottom.
Momo Steering Wheel Install, Illustrated
5th picture down, downs the turn signal cancel ring on a LATER steering wheel. This is the one where it's a separate piece bolted to the factory hub. The EARLIER hubs had this piece molded right into the metal, it's not removable.
This is the surest way to know which one you need. Pull the factory steering wheel, flip it over, and examine that turn signal cancel thingy.
The Momo 230 is the EARLY one. The Momo 231 is the LATER one.
Also ,this is all based on what I remember, having received the wrong hub once. There might be other differences between the 230 and the 231, but that was a MAJOR, easily recognized difference that could be checked on your car before you order.
Mike Bradshaw
Old 09-30-2016, 07:39 AM
I ordered them both just to be safe. Pelican Parts customer service indicated that the splines on the two hubs are different, and that only one of the two hubs will fit properly. Hopefully it will be an easy observation come installation time.
Old 09-30-2016, 10:20 AM
gearhead
That was my thinking as well.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 09-30-2016, 10:37 AM
Just to close the loop here...my date stamp was 7/74, but I needed the later (231) hub, NOT the one that was listed for for use through 7/74...
Old 10-09-2016, 01:20 PM
