How do you like to clean your front hubs
Have a set I am rebuilding, any specific tips on cleaning them easily? Do you knock the studs out first?
Thanks!
1967 912 (now w/ 50% fewer random holes in it)
911 w/ 3.2
1974 914 (3.2L swap underway)
1984 928s (S4 engine and suspension), 1987 928S4
Old 09-28-2016, 12:58 PM
Soda blast them; no need to remove the studs or bearing races.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-28-2016, 03:43 PM
Unless you're replacing the studs for some reason, leave them alone. Not needed to clean the hub.
If DIY, get a supply of latex or equiv. gloves to minimize the "yuck-in-hand" clean up, a plastic bucket, big enough to submerge one hub and some degreaser.
FWIW, here's a short list of degreasers/cleaners. Not sure if the blogger got paid or is really into testing and rating degreasers:
Top 25 for Best Degreaser
Water solubility is handy for rinsing. You'll need a minimum of one gallon, so shop accordingly. In addition, some of these may affect aluminum (e.g. Simple Green - check the archives, and Pine-Sol isn't), so make sure it's safe for soaking aluminum parts.
Do I need to remind NOT to use gasoline or other highly explosive liquid?
Cleaning a wheel hub isn't near prepping for brain surgery. It's perfectly acceptable to remove old grease with your finger, then clean the hubs with a supply of old rock and roll t-shirts and spit. One's threshold of "clean enough" is variable.
Sherwood
Old 09-28-2016, 03:44 PM
Had mine blasted. Quick, inexpensive and look amazing.
1982 911 Targa, 3.0L ROW with Webers
Old 09-28-2016, 04:01 PM
Thanks guys.
Sand blasting with fine media is out?
Old 09-28-2016, 04:28 PM
RETIRED
Joe Bob's Avatar
DIY water based degreaser "Purple Stuff" at Kragen's and others. 50/50 mix. Use a spray bottle and empty and rinse right after use, the stuff eats the pump mechanism.
2012 ML350 3.0 Turbo Diesel
Old 09-28-2016, 04:31 PM
DanielDudley's Avatar
Originally Posted by tdskip View Post
Thanks guys.
Walnut shells or soda.
Old 09-28-2016, 04:48 PM
Thanks guys
911 w/ 3.2
Old 09-28-2016, 05:11 PM
The main cleaning "hump" is the existing grease in and around the hub - probably mandatory before showing it to your friendly media blaster unless they provide concierge service. Bead or shell blasting is optional to make it look nice. Avoid using grit media.
Old 09-29-2016, 06:40 PM
Old 09-29-2016, 07:47 PM
blasted mine...
but you could use an eagle one product "MAG Wheel cleaner", or diluted a/c coil cleaner. Not for painted surfaces though.
Old 09-29-2016, 08:32 PM
Heres how they came out:
Old 09-29-2016, 08:38 PM
Neun 11
Guest
Posts: n/a
That looks great. Are the hubs then coated with something to keep them nice? Clara? Powder coat?
Old 09-29-2016, 08:53 PM
Not coated with anything. Didnt even think about it to be honest.
Old 09-29-2016, 09:00 PM
