I posted the other day about my car not starting after a spirited run. Turned out that the CDI was or became defective.
I had an MSD system installed and after driving it a couple of days definitely know the difference. It revs higher and more quickly; starts without fail and seems to improve mid-range acceleration performance. It does have a built-in rev limiter and I think that is good as she has no hesitation getting up there. The cost was way too high but with a defunct CDI and having to wait for several weeks for a rebuilt I took the plunge. In similar circumstances I would highly recommend it. Best, Tom |
If one is good, two is better
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
911SC Tinkerer
Whoa, Whoa, whoa... you replaced a really old part with a new part and you got better performance?!? STOP. THE. PRESSES.
JK. I replaced my Perma-Doom with an MSD Street Fire, high vibration coil, Magnecor wires and copper plugs. Talk about an update! I set my gap at .040", where did you set yours? -Steve
-'83 911SC Coupe SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc Last edited by merlinfe; 09-29-2016 at 05:59 PM.. |
My CDI fried 3 coils in short succession. 3 tows home. Got MSD.....now happy!
No msd for me
I put in a Daytona Sensors CD1 that comes with it own coil......been a great upgrade for years.....much better quality than overseas made MSD......
I mean the MSD is OK, but the Daytona Sensors or even a Crane is a lot better design and much better quality. My 2 cents. Hey the Bosch is a 50 year old design and could be 40 some years old in our old cars.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
merlinfe states:
I'm sure there are lots of comparable or even superior systems to supplant the CDI. I'm happy for the moment and with these old girls every moment counts before the next disaster!! Tom |
/ˈpɔrʃə/ PORSH-ə Fan
Steve is referring to your spark plug gap. It may need to be adjusted after going MSD.
Another vote for MSD StreetFire. Wonderful replacement over PermaCrap.
1984 ROW Carrera Sunroof Coupe Schieferblau 1982 US SC Targa Moosgrun 1977 US 911S Sunroof Coupe - SOLD |
Fleabit peanut monkey
Side note. The Permatune's that fail are the legacy units. Silver.
I have two of those $450 paper weights. That's 1990's dollars. The newer black jobbies are better. I have not heard of them failing. However, MSD is 60% of the cost including coil, but not including install. Regarding install, I spent two weekends installing a 6AL under the driver's seat. I am slow as molasses, though. One fastener or electrical connection per every two beers and at least one post on the board.
1981 911SC Targa |
i have an MSD in my 930 and I had one in my 77s.
the rev limiter was the main reason I put it in my 930. it let me remove the speed relay under the seat. the capacitor is the main point of failure in the BOSCH unit. the CAP is over 30yrs old and it is time for them to go bad. I have replaced several. putting in a new MSD you will see better performance over a failing bosch unit, but the bosch unit is still a great unit.
I set my gap at .040 with the MSD as well, seems to be ok. Maybe some gurus will chim in on spark plug gap.
83 911SC Targa 09 911 Carrera 78 911SC Coupe |
delete
Derrick Last edited by 1979-930; 09-30-2016 at 06:01 AM.. Reason: already answered |
I misunderstood the "gap" comment. My mechanic replaced the spark plug wires but, when I asked, didn't pull the plugs. Interesting. I wonder what they have been set at since they were changed a couple of years ago.
Tom |
One big caveat is as you stretch the gap the voltage increases to jump it and easier grounds than the spark plug tip come into play. That can include your hand with tired wires. I don't care for that sensation at all.
1981 911SC Targa |
Rutager West 1977 911S Targa Chocolate Brown |
911SC Tinkerer
Forgot to add that I went with a resistorless rotor. Very important part of the puzzle that is MSD.
-Steve
-'83 911SC Coupe SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc |
Reiver
Yes, and spiral wound wires (Clewetts etc.) no solid core stockers.
De Oppresso Liber Strength and Honor 5th Legion |
Did 83's have resistors in the rotors? I don't think my 81 did.
1981 911SC Targa |
Science is NOT optional
Seems like Steve at rothsport says 0.045 and forget it.
PCA member since 1993 |
911SC Tinkerer
-Steve
Just needed to make another rev limiting rotor resistorless for my '77 as it doesn't have another way to cut out spark at redline. I will probably upgrade my older MSD 6A to the 6AL and just put in the simple resistorless rotor.
Took a picture of the rotor after I Dremeled the epoxy and resistor out. I cut a piece of 12 gauge copper wire to fit tight and then tapped it into place, soldered and then re-epoxied it. Ohms were tested before each step to make sure my copper wire was touching nicely. ![]()
