A couple of dumb questions about my rear spoiler!
My 86 has a deck lid spoiler that was added by the original owner. After reading a thread from this past August, I think it's a Turbo spoiler rather than a Carrera spoiler. The rear part of the base, where it attaches to the lid, is a fair distance from the standard Carrera air grill, which would allow the spoiler vase to fit over a larger hole in the lid for an inter cooler. Anyway, at some point the deck lid was painted, and not only is the shade of white a bit off but there is a run near the right edge. I want to fix this, but I also would like to see what the car looks like without the rear spoiler. So, the dumb question is how to remove the spoiler. It looks to be attached by a bunch of 4 mm bolts and nuts, but the only way I can see to get a wrench on the bolt heads is to drop the air conditioning condenser out of the way and reach through the original air grill opening with a box end wrench. Is there another way?
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 10-01-2016, 09:28 PM
Banned but not out, yet..
RSBob's Avatar
All that to see what it will look like? There are thousands of pics here that will show you what your car will look like, probably in the same color. Sounds like you just want to mess around with the tail, which there is nothing wrong with unless your non-Porsche owner friends find out.
Old 10-02-2016, 06:48 AM
Recreational User
porschenut's Avatar
You do have to remove the condenser to reach the fasteners to remove the tail. No way around that.
That's a Turbo/SC tea tray spoiler, upside down. The Carrera should have a whale tail.
Old 10-02-2016, 07:07 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 you must loosen the condensor from the lid under the grill to access all fitments and if done properly by the dealer the 3 cross member strips to support at the lip held by sheet metal screws.
+1 Turbo Tail.
'85 Carrera Targa
PCA/POC
Old 10-02-2016, 07:44 AM
The upside down thing drives me nuts. I posted the picture from my I-pad and it looks fine when I the view the post on it. But, when I view the post on my android phone, the picture is upside down! BTW, thanks for your response.
1990 964 Coupe
Old 10-02-2016, 08:01 AM
+1 Turbo Tail.
That's part of the reason I'm thinking of removing it. It wasn't installed correctly. No supporting strips and no second gas shock to hold the lid open. But, in any event, I'm going to repaint the lid so it's a better match for the original paint on the rest of the car.
1990 964 Coupe
Old 10-02-2016, 08:07 AM
Removing the spoiler will reveal the mounting holes. Maybe better to source a replacement deck lid, then paint to match. That turbo deck spoiler not normally equipped on factory Carreras, yes?
Sherwood
Old 10-02-2016, 12:12 PM
Have a Carrera decklid and Carrera tail for sale in the classifieds if you want to return it to stock.
Old 10-02-2016, 01:01 PM
sugarwood's Avatar
1986 Bosch Icon Wipers coupe.
Old 10-02-2016, 01:43 PM
Occasional User
Cook&Dunning's Avatar
You could just replace the turbo rubber lip with a whale tail lip, if you wanted the proper Carrera tail.
Vince
2015 Boxster S, Black & Black
1989 Carrera Silver Coupe, Silk Grey - sold
2009 Cayman S White, Full Cocoa - sold
1972 911E Silver Coupe, Pepita & Black - sold
Old 10-02-2016, 01:59 PM
Which Tail?
"The Carrera should have a whale tail. "
The Whaletail was produced from 1975 -77 and is not correct for a 1986 Carrera. The 1986 Carrera should have a "Carrera Tail" which is different.
Rahl
Old 10-02-2016, 02:07 PM
DRACO A5OG's Avatar
Most welcome Brother.
Well, if you want to do it properly, find a used turbo arm and have it painted when you do the tail or cut out the triangular mounting piece from an 8 gauge sheet metal, weld the mounting bracket on to the existing arm to even out the pressure of the lid when closed. It is nearly impossible to align the lid with a functioning dual strut on d-side alone. It was simply not designed to use two on one side.
'85 Carrera Targa
PCA/POC
Old 10-02-2016, 03:02 PM
Thanks for all the good info everyone! There a few small bodywork issues on my car and I was hoping to repaint the engine lid to better match the original GP white, so I thought I'd pull the spoiler off myself beforehand. Who knows, I might like the look! Besides, if I keep it, I need to fab up the anchor on the right hinge for the 2nd strut. Thanks, and I'll shoot a picture or two later.
1990 964 Coupe
Old 10-03-2016, 06:54 AM
