jwakil's Avatar
Rattle noise going over bumps, under front floor board
I've had this annoying rattle in my 81 930 that seems to get louder after driving for some time and when I go on rough roads. Somehow it's not as noticeable when I first start driving. It seems like it is either in the front right suspension, in front of the passenger floor board, or where the AC evaporator is. It's been like this for several years and I want to cure the problem because it's driving me crazy. Its definitely not some small loose thing. It seems like something big and clunky. Anyone else have similar issue?
82 - Austin Mini 998
78 Mini 1275cc -totaled
83SC Euro w/77 3.0 Carerra Eng.--sold
Several other daily drivers not worth mentioning...
Old 10-05-2016, 08:33 PM
twistoffat's Avatar
My tip would be the torsion bars. If the bushings have dried up or the grease on the bars they could be knocking.
Old 10-05-2016, 09:28 PM
In addition to the above, when I bought my car I had a speaker for the alarm system that was loose and just sitting on the cover plate for the steering rack/fuel pump area. It could easily be something rattling around in that area.
Old 10-05-2016, 09:40 PM
tshebib's Avatar
Also, check the outer sleeve/bearing in the steering rack. You need to remove the accordion rubber boot to view. There is a star slip ring that holds the sleeve in and it is known to snap which will allow the sleeve to creep out of place. Don't forget to check the sway bar bushing as well.
Old 10-06-2016, 05:23 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
I had the "rattle" during the process of upgrading the suspension. See my thread, page 3.
The suspension upgrade!
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 10-06-2016, 10:38 AM
wrxnofx's Avatar
Jack the passenger wheel off the ground and take the wheel off. Grasp the lower part of the strut and try and move it left and right. If there is movement in there you would have a loose gland nut that needs to be tightened.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 10-06-2016, 12:59 PM
I had the same problem and it turned out to be a bad bushing ontop of the strut,you can try using a impact gun to tighten..
Sent from my SM-N910T using Tapatalk
Old 10-06-2016, 01:31 PM
My friend, Andy Chisholm, told me many years ago that when I heard a strange suspension noise from the front end, it was probably from the sway bar. Twice he was correct. R/Dave
Old 10-06-2016, 08:47 PM
jwakil's Avatar
Well, I checked everything underneath and all the visible joints seem tight. However, I noticed the camber brace in the trunk has a big gap which I don't know if it should be there or not. It is a Renline aftermarket brace. Should the top bolt be all the way down? I didn't jack up the car and try to move it, but I imagine if it was totally lose I wouldn't even be able to drive it. So my question is, is that gap normal?
Old 10-07-2016, 06:23 PM
