What is the difference between 65-73 and 75-77 mufflers?
I know this is a simple question however I wasn't able to find the answer- what is the difference between 65-73 and 74-77 mufflers?
Old 10-04-2016, 02:24 PM
Bill Verburg's Avatar
'65-73 have dual inlet mufflers and single drivers side outlet, as does '74 but I seem to recall the outlet being slightly different from the earlier versions
'74-89 are all single inlet on the drivers side and the same outlet as was used in '74
Bill Verburg
Old 10-04-2016, 02:31 PM
Ok- next question
Do all duel inlet 911 mufflers have the same width between the inlets?
Old 10-04-2016, 02:44 PM
I would rather be driving
jpnovak's Avatar
Yes. Factory 2-in mufflers have the same inlet spacing.
The difference between the 73-earlier and 74 is the angle of the outlet. It changed to have a more downward initial angle and then flattens out backwards to clear the rear impact bumper. The bumper changed in 73.
Old 10-04-2016, 03:08 PM
My 77 911S muffler is 2 in 1 out and has a sniffer tube welded with a cap for testing purposes
Old 10-04-2016, 03:54 PM
frankc's Avatar
Yes, the '77 911s with Thermal Reactors had a 2 in 1 out muffler, similar to the '74 muffler, except that they had additional pipe for the EGR system that was routed to the CIS intake.
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 10-04-2016, 07:53 PM
A more important question is the difference internally. Anyone know?
Sherwood
Old 10-04-2016, 08:20 PM
Bland
unclebilly's Avatar
The difference is this...
The bumpers are lower on the 74 on cars than the 73 and earlier cars. A early muffler needs to have the outlet tweaked down about and inch to clear the impact bumper.
Both are dual in, single out.
Been there, done that.
Old 10-04-2016, 08:39 PM
