What should be replaced on a 964 3.6 when the motor is out?
What are the must do's with a 964 motor out out of the car? I need to prepare my list for when the new motor arrives.
Old 01-05-2003, 05:42 PM
PRO Motorsports
Tyson Schmidt's Avatar
The o-ring and seal for the power steering pump drive.
The #6 intake spark plug wouldn't be a bad idea either.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 01-05-2003, 06:22 PM
PRO Motorsports
Also, I'd recommend replacing:
Rear-main seal.
Front crank seal.
Intermediate shaft cover plate o-ring.
You have to remove the rear engine cross-member to replace the last two, so might as well do them while it's out.
Also the same things on the upper rear of the engine that you'd do on an earlier engine with a clutch job. The pressure sender and the o-ring for the t-stat. (I know, the 964 doesn't have an engine mounted cooler, but there is still the same o-ring in that spot.)
2004 GT3
Old 01-05-2003, 06:37 PM
Thanks Tyson. The power steering pump with have a block off, but I will replace the rest.
Old 01-05-2003, 07:33 PM
makaio's Avatar
Paul, how long untill you have that 3.6 heart transplanted & on the road?
Old 01-05-2003, 08:00 PM
I should have the motor by the 25th. Everything that needs to be done to the car will have been completed by that time, so I am hoping by Feburary 1.
Old 01-05-2003, 08:47 PM
Buy them, sell them
Adam's Avatar
It probably wouldn't hurt to change all the plugs while it's out. A valve adjustment would also freshen things up. Saves you the headache down the track.
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 01-05-2003, 09:14 PM
