87 Carerra, 3.2 liter en
Fuel Pump Jump
I am in the second phase of my no-start issue on a 1987 911.
I have finally resolved my no spark issue, having found the culprit with a broken wire in my Sensor HARNESS, not in the speed sensor itself. Simply due to the broken wire I was not getting any reading whatsoever no matter what new sensor I plugged in. I now have all of the OHM and AC volt readings for both sensors and have a strong spark at the coil.
But now I am turning my attention to the fuel side. I have two new dme relays and I hear them both clicking when I turn the key on. But I do not hear the fuel pump turning on. Can someone please tell me how to jump the fuel pump to get it running to see if the car will start.
I did do all kind of searches on this and most of the posts spoke about jumping the fuel pump and bypassing the dme relay without really telling how to do the processes.
Can someone set this out for me step by step as I am making serious gains with resolving my no-start issue
Old 10-12-2016, 07:16 PM
autojack's Avatar
It's explained in the Bentley manual. See Broken down near Pt. Reyes, CA
Old 10-12-2016, 08:11 PM
Administrator
Luccia at Pelican Parts's Avatar
Hi Srwilliams - You can also post this question in the comments/suggestions section at the bottom of this tech article here: Porsche 911 Fuel Pump Replacement | Pelican Parts DIY Maintenance Article. Casey or Nick might have your answer. This might also help by having it listed in the tech article itself for someone to view in the future if they need to do the same. Or you can purchase the Bentley Manual here as it has a lot of great info: http://www.pelicanparts.com/catalog/SuperCat/0814/POR_0814_TOLBKS_pg1.htm#item0. Good luck.
Old 10-13-2016, 10:19 AM
I dont recall the terminals off the top of my head, but i hated using a scrap of wire and made this. It doesnt fall out, spark or move around and made trouble shooting this system a little easier.
1982 911 Targa, 3.0L ROW with Webers
Old 10-13-2016, 11:07 AM
Man did not realize I owned the Bently manual and went right to the pages you guys suggested and successfully jumped the fuel pump. Thanks you guys
Old 10-13-2016, 03:21 PM
Irrationally exuberant
ChrisBennet's Avatar
For someone coming to this thread later:
I believe the fuel pump fuse is #6. For testing, I just bridge the fuse holder for #6 and #5 with something metallic like a screwdriver or coin to make the fuel pump run. #1 is the closest fuse to the driver.
I just did this the other day to pressurize the fuel system to test for leaks after installing a newly rebuilt motor.
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-13-2016, 04:59 PM
