I'm all about seat time, and can guarantee I'll be maxing out next year. Still not sure about the wheels though. I'm a big fan of empirical data so I'm going to pursue that. I have some RS-3's NT01's and RT615K's for my Scirocco but I've heard they don't hold a candle to the RE-71R's (well....the NT01's do but are technically R Compound) |
Also, I'm bouncing off redline in 2nd gear at points which is about par for the course. I'd have a hard time conceiving wanting to be geared even lower. The autocross track we have is an airport that tends to be a quick mile+. |
Miata battery or the AGM 25lbs battery will work. After all the weight removal do the corner balancing. I have to redo mine because of lighter starter and muffler. |
The updated starter is lighter? Which one is this?? For my Scirocco I got a Featherweight lithium ion battery. Thing is suuuuuuper light. Very expensive though to get more CCA. |
What torsion bars are in your car now? |
Sway bars are stock for the moment. Raise the spindles? You mean cut and Fab them? Sounds dicey. I also installed Weltmeister steering rack spacers. Cheap and does the trick. For weight reduction, have you guys seen this?? Wps Featherweight Lithium Battery 500 Cca Hjtx30L-Fp-Il Hjtx30L-Fp-Il I bought a 200 CCA one for my Scirocco which does the trick.....but with these batteries you're talking ounces....not pounds. |
Those big fat tires hurt you in three other ways. One, they're probably 50 pounds heavier, as a set, than what I suggest you run. Two, they will have a much higher rotational moment of inertia, which kills your acceleration. Three, they are taller, so you effectively have taller gearing. Quote:
You need to fix the problems your car now has, and it is far from optimum for autocrossing-trust me on this, and you need more seat time. Have fun, JR |
In my very limited experience (though I've done lots of watching, listening, and asking), tires alone can be worth 3 seconds on a course that long! And if you've never experimented with lighter vs heavier wheels + tires, it's crazy how noticeable that difference is. Shorter diameter is even better for acceleration, though in certain situations that could just set you up to lose time on an extra shift.
Either way, the 964 driver clearly knows how to throw that floppy 'vert around the cones. I absolutely agree that a 3.2 coupe should be quicker given the same driver (and equal tires). One common thing all of the quickest autocross 911s seem to have are custom-valved shocks. I'm not sure anything off-the-shelf aside from coilovers (which probably class you out of competition) is ideally valved for autocross. |
Your old RE050s are clearly at least 3-5 sec off new RE71Rs. That's the first thing you should change. 225 and 255s on the 17s should be good. Set your alignment to at least -2.0 camber f, 2.5 rear, with 0 toe front, proper corner balance and you should fly.
A good rule of thumb is that each 100-110 lb weight reduction is good for a 1.0 sec reduction on a 1:30 track lap, or 75 sec AX course. You can see that on AX lap times when a passenger rides along. The subject of weight reduction is a long one. The first 150 lbs are the cheap and easy ones. Regarding HP, a good rule of thumb is each additional 10 HP is good for a 1.0 sec lap time reduction on a 1:30 lap. So a 15 HP mod is good for a 1.5 sec reduction. Make sure you are getting full throttle at the throttle body and that the full throttle microswitch is working and activating. I used to run 22mm sway bars front and rear on my 3.2, but on the advice of Rich Walton of JWE, changed to Smart Racing 31f/27r and the car was instantly 1-2 seconds faster. You could literally dive head on at a cone, heel toe into first, and throttle steer the rear end 180 degrees around it and power out. Brakes do get hot in AX. Good ventilation, a set of Raybestos ST-43 pads, and Endless RF650 brake fluid are a good start. |
The 964 driver is very very good. He does know how to "throw that floppy 'vert" :) I have dampening adjust on the front but non-adjustable rears. Probably on my to do list. Coilovers would throw me into another class I'm pretty sure...yeah. |
I feel I don't have the rear grip right now to throttle out like you said hehehe, maybe with the new RE71R's. Also, thanks for the Camber specs!! I am probably running too much front camber and not enough rear at the moment. Eager to get that alignment and corner balance. |
your car looks like it is doing pretty well I the pic, no excessive body roll.
if you can get the 225/255 in a 15 with the same profile spend the money on the rims. that is like adding HP, it lowers the CG by 2 inches which is a lot which is also a BIG improvement without changing the suspension geometry. your looking for 3 sec out of 75sec on a low speed course, that's a lot of time. you need the acceleration. trying to increase your cornering speed takes a lot of $$$ + you have to be able to utilize it in your driving skills. getting from one turn to the next is easier to improve. say you have a 30 turn course. that's .1 sec per turn or .1 for accel for 3sec improvement. keeping one or the other the same, which would be easier to improve. |
Oversteer can occur on the entry into a corner, through the corner and exiting the corner. Don't confuse the basic balance of the car with oversteer that arises from driver inputs. Quote:
In my area, the fast guy is fast in his car, or in any other car he sets his butt in. He'll beat anybody's best time, in their own car, the first time he runs it. It doesn't matter if it's a 100hp 914-4, or a 600hp uber-Porsche. He's that good. Modifying these cars isn't cheap. I'd rather have one car that was set up well than two that were set up poorly, so maybe my priorities aren't in line with yours. I will say that any advice I get from people that have spent a lot of time learning it usually get my business. I'm working on a car now that I've talked to Chuck about. When I get to the point of buying parts, he'll get my business as a reward. Good luck to you, JR |
By the way, in several of the photos you've posted of your car, I see a lot of tire smoke. Your corner balance is probably a mile off and your tires may be long past their useful life. Swapping tires and re-aligning the car will help a bunch, but I'd do all the other work first, so you don't have to corner balance the thing more than once.
JR |
I have an 86 Carerra that I've autocrossed for years.
-Fully agree with everyone suggesting 15s. I run 225/45Hoosiers on Fuchs 7/8X15s Running a square tire setup lets me move the tires around as needed to equalize the uneven wear. There is still a bit of tire footprint difference (maybe 1/2 inch) front to rear because of the different width wheels. -Get the car as low and stiff as possible. Adjustable sway bars enable fine-tuning the front/rear balance to suit your handling taste. -I run SSIs and a SW chip. The car pulls very quickly from 2-5000rpm in 2nd gear, where you will be most of the time. -Aggressive weight reduction with FG bumpers would be the next step for me. |
You need adjustable sway bars to get the most out of the car. It has way too much understeer now. Yes, cutting and welding is required to raise the spindles. Not dicey at all. It is done all the time. |
I did some math and I think my setup is 17lbs heavier. I think ideally I'd find lighter 17" wheels. Our courses are a lot of corners and slaloms. I also feel like 205's would look stupid on the rear of my 911. Maybe it's a negligible concern and I'm being prideful, but I like having big meaty tires in the rear. https://c8.staticflickr.com/9/8274/2...4d10d310_b.jpg https://c6.staticflickr.com/9/8135/3...ced887bf_b.jpg |
| All times are GMT -8. The time now is 12:02 AM. |
