2.7 cam timing
First off, thanks to those who replied to my previous thread. I now have a set of 2.7 Carrera cams #143 &144. Does anyone have the timing specs to set up these cams? My dial indicator is imperial, not metric. I'll do the conversion if needed. Thanks, Craig.
Old 02-12-2018, 05:53 PM
Functionista
manbridge 74's Avatar
I usually refer to spec book but from Wayne’s... 0.40-0.54mm at overlap TDC with 0.1mm valve clearance.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 02-12-2018, 06:10 PM
