G50 Pedal Cluster Bronze Bushing Kit?
Trying to find a rebuild kit for my 88 3.2, but all I can find are the ones for non G50 cars...anyone know of a source? I cant find it in a Pelican Parts search for some reason....only the OEM plastic ones for the brake and clutch pedal. My pedals are sloppy and hoping there is a bronze bushing kit available.
2018 991.2 Cup Car
2014 997 GT3-R
2010 997.2 Cup Car
1989 911 3.2 Coupe
Old 10-25-2016, 06:57 AM
steely's Avatar
I think I went thru this search as well and unfortunately I wasn't able to find an all bronze kit for the G50 pedal cluster.
This was a couple years back (<5), so maybe some industrious person started a cottage industry.
This was the only bronze bushing I could find: Accelerator Lever Bushing, Bronze, 911/911 Turbo (1974-89) 901 423 253 00 M105
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 10-25-2016, 03:14 PM
buy some bronze bar and make them yourself its pretty easy
Old 10-25-2016, 10:55 PM
thanks for that info and p/n steely!
.....thanks.
2018 991.2 Cup Car
2014 997 GT3-R
2010 997.2 Cup Car
1989 911 3.2 Coupe
Old 10-26-2016, 05:40 AM
Something else to check:
When my G50 pedal cluster felt sloppy, I went to rebuild it and found my main shaft was tearing itself apart -- splitting like a piece of celery might!! Pelican found an NOS Porsche shaft in Germany for me. I think I used the plastic bushings, and they've been fine for hundreds of kmiles.
HTH,
Chuck.H
'89 TurboLookTarga, 422k miles
Old 10-26-2016, 06:09 AM
www.*********.com/dqwk12z-porsche-911-control-pedal-bushing-set.html
www.*********.com/vhbz7lq-porsche-911-control-pedal-bushing-set.html
replace stars with "*********"
Take your pick
Old 10-26-2016, 09:54 PM
88 Carrera, Guards Red
azhodge's Avatar
Pedal cluster
automotion Kit bronze bushings and role pin
Old 11-14-2016, 12:06 PM
Diss Member
Quicksilver's Avatar
It says that those kits fit years 65 through 89. If it fits the earlier years there is no way if fits the G50 cars. If they do cover all those years I think it is a pretty good bet that it fits the CIS turbo cars not the G50 DME cars.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 11-14-2016, 12:29 PM
Mick_D's Avatar
What's different about the G50 pedal cluster from older models?
Old 11-14-2016, 12:47 PM
steely's Avatar
Since the G50 is hydraulic, they modified cluster frame to accommodate mounting of the clutch master cylinder on to the frame in line with the clutch pedal - instead of a bearing tube and clutch pedal shaft that pulls a cable in the tunnel. And with the hydraulic clutch, since there is no cable to adjust, they added some hardware in the cluster to adjust the pedal throw. The brake pedal config is different too.
I hope this helps, pic isn't that great.
Dan
Venetian Blue
Old 11-14-2016, 01:25 PM
old man neri's Avatar
PM'd
Old 02-12-2018, 03:04 PM
Red Line Service
Marc Bixen's Avatar
Use the factory poly bushings. I'm not a fan of bronze, besides the originals lasted 30years. Also ALWAYS replace the clutch shaft 911-423-216-06 they wear out at the roll pin, and the roll pin N-023-351-1 Qty 3. You'll thank me later.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 02-12-2018, 05:15 PM
