Hand Throttle for a Carrera
There are times when it would be convenient to be able to increase the idle speed without sitting in the cabin with a foot on the accelerator pedal or using one hand on the throttle linkage. Simple enough to implement with a long Bowden cable. Where is the best place to attach such a cable to the throttle linkage?
Old 04-17-2017, 04:25 PM
In my rockcrawling Jeep, I have a hand throttle using an old-style bicycle shift lever attached to the Jeeps shifter lever. Not sure I see the need in the 911, but in the Jeep it's super handy when winching or jump starting somebody or even as a crude cruise control. Also good when your feet are busy with the clutch and brake but you need to bump over something.
Chuck.H
'89 TurboLookTarga, 430k miles
Old 04-18-2017, 04:44 AM
E-85 sippin drunk
turbobrat930's Avatar
Chuck.H
Bingo^^^^ Thats exactly what I did in my rock crawler Jeep as well.
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 04-18-2017, 06:58 AM
Why not the Flintstone solution, keep a brick handy?
Old 04-18-2017, 09:56 AM
easy enough, I used a 924 heater valve plumbed into the large diameter air tubing/hoses on the engine, and a bowden cable. Has worked well for several years
80SC (ex California)
Old 04-18-2017, 10:03 AM
82 SC's Avatar
Here is what i had in my pinzgauer, you could pull it out and turn to lock the throttle where you want it. Looks like the cable attached to the gas pedal.
Swiss Army Vehicles - Detailed Part View
Swiss Army Vehicles - Parts for Pinzgauer, Unimog and Haflinger
1982 SC "Spooky"
1961 VW Single cab truck
1966 VW Deluxe Hard top
Old 04-18-2017, 12:31 PM
82 SC's Avatar
Here is a photo from the link i just posted. pretty good price too.
1982 SC "Spooky"
Old 04-18-2017, 12:35 PM
How about fitting the same hand throttle as standard on the
1974 911. Worked well as a cruise control too
_______________________________________________
45 yr addiction 1965 356 Coupe, '70 914- POS, '74 911- lightweightFUN, '83 SC Cab- 100%AnalogOpenTop.
Old 04-18-2017, 12:58 PM
Vintage Owner
Jack Stands's Avatar
Could you rig it up that the passenger side heat lever operated both heater flaps (as on the pictured cat) and simply use the driver's side lever as a hand throttle?
On the 914-6, the hand throttle simply activated a rod that pressed on a tab on the accelerator cable up by the pedals. May be another possibility?
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 04-18-2017, 02:49 PM
