Noob here, Tire pressure? 1981 911 SC
I am a new SC owner, car currently has REAR245/45/16 94W Front 205/55/16
Do i use the reccomended tire pressure stamped on the car or is the pressure more in accordance with the tires?
Nice car Skoul! I've found 2-3 pounds under recommended pressures keeps tires from wearing out at center. Some will go over pressure for a tighter "feel." Think it boils down to personal pref. Suggest you test under / recommended / over pressures to see what works best for you. (Personally... I dislike tossing tires because they're worn out in the center.)
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
I think your tires are on backwards.
JUAN '80SC Targa |
I run 36 PSI on all 4 corners.
Billy, MoosgrunMetallic - 81 911 SC - (Carbon fiber Wrap) Drank the Koolaid in 82 |
I run 30psi front 205/55/16 and 35 rear 225/50/16.
82 911 SC |
245 s are very hard to find in a 16 inch wheel now. Unless they are Toyo r888 or some other track tire they may be expired. My car came with "new" looking tires. Checked the date codes and they were fifteen years old. Check the dates.
82 911 SC |
I run 29F 34R Cold Temps
83 911 Production Cab #10
They are fine on your car but not in your post...
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Ahh i got it.
My mistake.
Front 205 55 16 Rear 245 45 16 I went with 29f psi 34r psi Start there and see where it go's Thanks guys. |
RETIRED
Good idea to install stem supports for the rears.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Diss Member
Should be more of a "REQUIRES valve stem supports." I had one walk out at speed right after I got my car. Very "exciting".
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Amazing how far out those armor clad tire valves will go. Usually, you can see a witness mark on the rim where the metal cap has touched.
Member 911 Anonymous
Per Darin at WestSide Alignment. He recommends 4 lbs difference. So he filled mine to 31F 35R cold. Tires are wearing much better now and control is optimal.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I run 30/35
