Noob here, Tire pressure? 1981 911 SC
I am a new SC owner, car currently has REAR245/45/16 94W Front 205/55/16
Do i use the reccomended tire pressure stamped on the car or is the pressure more in accordance with the tires?
Old 11-05-2016, 10:48 AM
Discseven's Avatar
Nice car Skoul! I've found 2-3 pounds under recommended pressures keeps tires from wearing out at center. Some will go over pressure for a tighter "feel." Think it boils down to personal pref. Suggest you test under / recommended / over pressures to see what works best for you. (Personally... I dislike tossing tires because they're worn out in the center.)
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 11-05-2016, 11:06 AM
I think your tires are on backwards.
JUAN
'80SC Targa
Old 11-05-2016, 12:05 PM
urseppos's Avatar
I run 36 PSI on all 4 corners.
Old 11-05-2016, 12:24 PM
Kool-aid-82's Avatar
Ditto...
Billy,
MoosgrunMetallic - 81 911 SC - (Carbon fiber Wrap)
Drank the Koolaid in 82
Old 11-05-2016, 12:26 PM
I run 30psi front 205/55/16 and 35 rear 225/50/16.
82 911 SC
Old 11-05-2016, 12:50 PM
245 s are very hard to find in a 16 inch wheel now. Unless they are Toyo r888 or some other track tire they may be expired. My car came with "new" looking tires. Checked the date codes and they were fifteen years old. Check the dates.
82 911 SC
Old 11-05-2016, 12:54 PM
Originally Posted by Kool-aid-82 View Post
Ditto...
Two front tires.
Two rear tires.
WHat does that mean backwards? here are close up pics. TY
Old 11-05-2016, 01:00 PM
MARISOL78sc's Avatar
I run 29F 34R Cold Temps
Old 11-05-2016, 02:23 PM
83 911 Production Cab #10
JJ 911SC's Avatar
They are fine on your car but not in your post...
I am a new SC owner, car currently has Front 245/45/16 94W Rear 205/55/16...
Who Will Live... Will See
Old 11-05-2016, 03:04 PM
Ahh i got it.
My mistake.
Front 205 55 16
Rear 245 45 16
I went with 29f psi 34r psi
Start there and see where it go's
Thanks guys.
Old 11-05-2016, 03:10 PM
RETIRED
Joe Bob's Avatar
Good idea to install stem supports for the rears.....
2012 ML350 3.0 Turbo Diesel
Old 11-05-2016, 05:17 PM
Diss Member
Quicksilver's Avatar
Should be more of a "REQUIRES valve stem supports." I had one walk out at speed right after I got my car. Very "exciting".
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 11-06-2016, 02:23 AM
Amazing how far out those armor clad tire valves will go. Usually, you can see a witness mark on the rim where the metal cap has touched.
206 637 4071
Old 11-06-2016, 07:19 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Per Darin at WestSide Alignment. He recommends 4 lbs difference. So he filled mine to 31F 35R cold. Tires are wearing much better now and control is optimal.
'85 Carrera Targa
PCA/POC
Old 11-06-2016, 07:25 AM
JJ 911SC's Avatar
Originally Posted by DRACO A5OG View Post
... He recommends 4 lbs difference...
+1, I'm 32F & 36R
Old 11-06-2016, 12:23 PM
I run 30/35
Old 11-06-2016, 02:27 PM
