1976 911S Targa
Head Light Switch Removal
How is the head light switch removed?
1976 911 S
Old 10-18-2014, 08:44 AM
Member 911 Anonymous
DRACO A5OG's Avatar
You need to pick tools and counter clock wise spin the retaining ring off after removing the knob straight out.
Search for schematics or label each before disconnect all the wires.
CAUTION, Disconnect the Battery.
'85 Carrera Targa
PCA/POC
Old 10-18-2014, 12:41 PM
French Import
zippy_gg's Avatar
Is the light switch on the 86 different?
I tried removing the knob pulling straight out, and also turning counterclockwise (while holding the shaft with a mini visegrip) and no dice. I don't want to break anything in the process...
Edit: The Bentley has a great picture showing the 10mm nut at the end of the shaft
Alas the old brittle plastic cover with the light logo broke into pieces...
I'll try to source one...
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 11-07-2016, 03:53 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Headlight switch.
Disconnect the battery prior to removing switch.
Here are the color codes & connections for our '86.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-08-2016, 06:46 AM
French Import
zippy_gg's Avatar
Thank you Dr. Gerry!
Battery disconnected, and old wiring removed with great difficulty as the PO added a stereo system with a lot of oversized wiring and looms.
I should be able to have it back together by COB today.
Gilles & Kathy
Old 11-08-2016, 09:49 AM
