915 transmission - 1st gear has become 3rd gear
Guys,
I drove the car a few days ago after having it parked a few days. Final drive before parking it was totally normal. I got back in and seem to not have first gear or second gear anymore. The shift lever is in the right spot for first, I can move it through all six positions, and reverse works. It shifts easily, the issue is that it barely takes off from stop due to lugging (gear too high) - I know it's a trans not an engine issue because I can get all the way to 60mph without shifting - it's definitely in 3rd. What's weird is I can't feel at all another stop on the left of the shift pattern, so it doesn't seem to be a coupler/shifter issue at all -- and if I drive through the gears, I get 3-4-3-4-5 What could be going on inside the 915 that would cause it to stay selected in 3-4 when I go to 1-2 plane? Very strange. Clutch/all else seem normal. Thanks in advance... |
Immediately when seeing your thread title, I was going to suggest the shift coupler has loosened/moved.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Retired, finally
Or the shifter bushing has disintegrated.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project |
+1 on bushings. I replaced the ball/cup bushing a couple of weeks ago and didn't get it fully seated. The shifting was very odd and I don't think I was getting all gears. It felt like a gated shifter, which mine most certainly is not.
Matthew - drove Nurburgring with wipers on and no rain 1969 911E SOLD ![]() 2002 996 Cabrio 1995 993 Carrera 4 SOLD 2004 Land Rover Discovery II G4 Edition (Sold )
as MBATarga said, something in the shifting mechanism / linkage has loosened.
Steve |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Shifer bushing.
I agree, just went through this. Also, the shift coupler. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Past: 04 Anniversary 911 #0895, 82 911 SC, 88 Signature Series Carrera, 88 911 Turbo Cab, 73 911T, 63 356B, 06 Cayenne |
All new bushings. Should have said that first. Shift coupler is WEVO PSJ, shift rod bushings (cup, rod bushing) are new. But I guess I need to check those. Any other ideas?
The fork inside transmission get loose. but easy fix.
I think there are a tread about that somewhere.
Daugaard |
Update for the searchers who might have stumbled onto this thread: My shifting problem has been resolved. The issue was the set screw on the WEVO PSJ shift coupler had gotten loose, and was allowing the coupler to twist on the shaft. I retightened it along with some blue thread locker and we should be good to go now. Even if you're using the stock coupler or a rebuilt one, this could be an issue.
Onward!
Jason - Austin, TX 82 911 SC targa (gone, but not forgotten) 92 968 coupe |
Schleprock
Put a jam nut on the pointed coupler set screw and you won't have to bother with any threadlocker in the future.
Credit for the photo goes to JWest Eng.
Kevin L '86 Carrera "Larry" |
