3.2 in 71 911
Need some advice. What are the drawbacks of putting a 3.2 Carrera engine in a 71 911T? Does the extra weight create any issues?
Old 11-04-2016, 05:18 PM
al lkosmal's Avatar
The 71 2.2 weighs about 400lbs and developed 125-180hp (TES) depending on model
the 3.2 weighs about 480 lbs and is 230hp or so (1.5 - 2x the HP/TQ)
More weight, but significantly more power........
I had a 3.2 in my 73T...combined with a 915 with 7:31 R&P, LSD ...a total blast.
Also it was flared a little, had 7&9s, 23/31 T-bars, front swaybar, etc....I never noticed the added weight.
RGruppe #669
http://www.x-faktory.com/
Old 11-04-2016, 07:02 PM
Vintage Owner
Jack Stands's Avatar
It should make the car a blast to drive and the drivability of the Motronic engine is great.
The extra weight is an issue and I'd be concerned about a 901 transmission taking the additional torque without giving up eventually. However, if you take off gently from a standstill, it should hold together. Remember, Porsche changed from the sturdier 915 transmission to the G50 while using the 3.2 engines.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 11-04-2016, 07:08 PM
LakeCleElum's Avatar
What Al sez (About the very nice 73 he bought from Dantilla)......I have a high compression 3.2 in my 73.5....Most fun you can have with your clothes on.....Never noticed the extra weight while picking up 80 RWHP......
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 11-04-2016, 07:21 PM
al lkosmal's Avatar
+1 motronic is great............I was warned that the 3.2, 7:31 combo was a possible accident waiting to happen, but it worked very well. Also....regarding engine cooling. I had Elephant Racing ribbed oil lines with Wide mouth cooler. Worked great...........
RGruppe #669
BoxsterGT's Avatar
Porsche Crest
A minor issue is the 71 911 has 26mm Oil Hoses while the 3.2 motor has 30mm Oil Hoses. Also, the 71 oil tank has a threaded fitting on the supply to the motor while the 3.2 motor has a slip fitting (the "S" Hose).
Both these issues easily remedied with custom fittings and hose.
Len
Old 11-07-2016, 08:49 AM
kent olsen's Avatar
I wanted more performance in my 72 years ago so purchased a 2.7, then later wanted more. Mag cases are very expensive to gain more power. I had already removed 250 lbs of weight so I just wanted power with reliability. Went to to 3.0L aluminum case. Added twin plugs , 42mm custom webers and got 245 hp and 8.9:1 power to weight. This 3.0L was built to be bullet proof and has taken everything I've thrown at it.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 11-07-2016, 09:10 AM
Under the radar
Trackrash's Avatar
Lots of people have successfully swaped 3,2s into a '71.
There are a number of details to attend to. Do a search, this used to be a popular swap.
The oil tank, as mentioned, needs to be replaced or have fittings adapted. The '71 tank will probably be OK for the street.
The transmission in a '71 has a weak first gear, again probably OK for street cruising.
The transmission case will have to have a cut made to allow the flywheel sensors on the 3,2 to work.
There will be wiring issues, matching the engine harness to the chassis needs work.
The '71 ignition CDI and tach wont' work. Make sure you get the entire ignition and all the Motronic controls from the 3,2.
What exhaust will you use.
Good luck.
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-07-2016, 10:44 AM
BoxsterGT's Avatar
Porsche Crest
Buddan- Wondering how you are coming with your engine swap.
I can help with both Oil & Fuel Hoses.
Len
Old 12-02-2016, 04:22 AM
My current project is a 3.2 on a 70
Old 12-02-2016, 04:29 AM
Len
I have not found a 3.2 engine yet.
Old 12-02-2016, 07:57 AM
Good luck.
With a 3.2 you probably wouldn't need to use first gear.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 12-02-2016, 09:16 AM
It's really hard to keep the smile off your face when driving it....
1971 911T British Racing Green 3.2L
2013 981 Boxster S Aqua Blue/Grey
2014 981 Cayman S Agate Grey/Black
enjoyed and passed along:
1990 964 C2, 2007 C4S Cabriolet, 1997 986, 1958 356 A
Old 12-02-2016, 01:01 PM
I went the option of fitting an MSD (re-curved distributor) and Webers on my 3.2 and consequently don't believe there's a huge weight difference. Bullet proof engine upgrade and it looks like the original 2.0.
Cheers
Paul
1969 Porsche 911T 3.2 (Matching # engine safely in storage)
2021 AMG C43
2020 BMW X4
1979 Californian Moke
Old 12-02-2016, 02:37 PM
78-911SC's Avatar
Do you think you could get away with a stock baffled oil tank without having any aux oil cooler up front or in fender? 70T probably street use.
PJ
78 911sc Targa
70 911T
Old 12-02-2016, 05:11 PM
Under the radar
Trackrash's Avatar
For a 70 T motor, yes.
Gordon
Old 12-02-2016, 06:51 PM
78-911SC's Avatar
Funny Gordon. Really I'm wondering with a 3.2 is it necessary to have a cooler up front somewhere or can I use the stock cooler with baffles added.
PJ
78 911sc Targa
70 911T
Old 12-03-2016, 12:44 PM
Old 12-03-2016, 01:48 PM
