Installing rear sway bar
I am looking to fit a rear sway bar on my 1974 911 that has not previously been having one, i.e. no mounting brackets are welded on, etc. So, now I am researching what to get and notice that most seem to have the drop links that attach to the ball on the trailing arm. Do all rear sway bars attach this way or are there other kinds? The problem is that I seem to be missing the ball attachment point on one of the trailing arms.
Thanks! |
Retired, finally
The Tarett bars attach to the rear spring plate using the camber adjustment bolt.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project |
Not as it seems
wevo makes a really good weld on mount. if using a larger bar such as the smart racing unit mock it up before you weld them on. there can be a very tight fit where it runs across the trans cross member.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
