What can I use to clean caked on oily grime?
I have a ton of black, oily crud from the oil filter being changed and not cleaned up from the drips. 30 years of road debris mixed with oil makes for a mess.
What can I use to clean all of this crud? Keep in mind I'm doing this from my 2 car garage... so I don't have access to take this to a professional restoration shop to have the body stripped and sand blasted.
Can I use a high pressure water cleaner? or some chemical mix with a toothbrush? Or a combination of the 2 with some high pressure air?
Thanks!
Old 11-25-2016, 03:15 PM
Detached Member
Hugh R's Avatar
Try aerosol brake cleaner
Hugh
Old 11-25-2016, 03:18 PM
I use kerosene in a spray bottle and a brush. rinse with water between scrubbings. Brake cleaner will take off the paint
Old 11-25-2016, 03:30 PM
Will a toothbrush work? I'm worried brake cleaner would be too corrosive. Any suggestion on how to get to the hard to reach areas?
Is it safe to just hit it with a high pressure washer?
Old 11-25-2016, 04:02 PM
Reiver
Reiver's Avatar
Original Gunk
De Oppresso Liber
Strength and Honor 5th Legion
Old 11-25-2016, 04:13 PM
gduke2010
gduke2010's Avatar
be careful w/ brake cleaner. I use Gunk or Simple Green
Old 11-25-2016, 04:26 PM
Project Addicted
Elbow grease. A few plastic scrapers and I like the original gunk too. I also have one of the home steam cleaners and it's the bomb for final clean and it get all the crap out of the nooks and crannies.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 11-25-2016, 04:29 PM
yes i usually use a toothbrush. brake cleaner is not only too corrosive but it evaporates right away. it works great for final cleaning of bare metal surfaces but anything else there are better options
Old 11-25-2016, 04:32 PM
sugarwood's Avatar
Post a photo please.
Learn to post photos for all your questions.
You will get better answers.
Simple Green is a favorite here.
You can get a gallon of concentrate (lasts for years) for $10 off Amazon.
https://www.amazon.com/Simple-Green-Industrial-Degreaser-Concentrated/dp/B01MAYGHY5
1986 Bosch Icon Wipers coupe.
Old 11-25-2016, 04:53 PM
crustychief's Avatar
I used diesel on mine, on a bunch of old towels. it worked pretty good.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 11-25-2016, 05:16 PM
esses62's Avatar
Orange oil based tar remover Karnak you can buy a spray bottle at your local Home Depot lowes where they sell the roofing materials works like magic
Scott
88 911 G50 3.2 Targa Signal Red DP935 NA
95 993 C2 Coupe Black/Black
99 996 C2 Silver/Blue
77 911S GP White/Cork
Old 11-25-2016, 05:56 PM
I've had good luck with Simple Green and Pinesol (both non-diluted - apply straight, soak, scrub with a brush, rinse away with water, repeat).
Spray-on engine degreaser is also effective, but I always seem to use a lot more of this than Simple Green or Pinesol.
Old 11-25-2016, 06:41 PM
I recently removed the rear bumper from my 77 targa to replace the oil lines and exhaust. A leaking oil tank sending unit allowed dirt and oil to accumulate everywhere- especially inside the valence and bumper. I used a plastic scraper (putty knife) with Purple Power cleaner. I love the PP cleaner but you must be careful because it contains lye. I buy it in gallon containers from Walmart.
Old 11-26-2016, 02:58 AM
Puma's Avatar
I cleaned 48 years of thick, nasty funk on my transmission to a sparkly, shiny, like new standard with paint thinner and a toothbrush. Worked very well.
2001 986 S
Old 11-26-2016, 07:51 AM
ok... whatever you want.
Old 11-26-2016, 08:37 AM
Air Cooled-6
Rumble-Bee's Avatar
Cleaning Grime
I have found WD-40 to work pretty good. Its a penetrant oil that can dissolve crud -- also its not harsh on anything. I've even used it to clean grime bits off of my exterior paint.
Old 11-26-2016, 10:34 AM
Air Cooled-6
Rumble-Bee's Avatar
Whoa there! Reminds me of my 70 911T that had a leaking rear main for a long time. I bought a cheap power pressure washer from Harbor Freight, and that was just the ticket to get all the thick caked on crud off my engine, trans, and engine compartment. I could have eaten off that trans when I was done. Be really careful NOT to hit any painted areas that you care about with the stream (or any body parts you value). I used plain cold water with no cleaners added. Cleaner additives may have helped.
My only complaints about the power washer was that:
1) You're going to get very wet
2) All of that crud comes off in chips that get scattered everywhere, then they were stuck to my driveway -- I should have used a big tarp to protect it.
3) Wear eye protection & clothing you won't mind discarding
For finishing touches I used WD-40 & a part brush (toothbrush is OK too).
Old 11-26-2016, 10:50 AM
sugarwood's Avatar
Funny about the picture.
OP said the oil filter, so I was wondering how much crud we were really talking about back in the engine bay.
I've never looked back there. Do you think that's from oil filter dribblings, or from leaking oil pipes?
Old 11-27-2016, 07:16 AM
Paint thinner is the best in my opinion…………..and I've tried them all over the years.
Old 11-27-2016, 07:21 AM
When i use a pressure washer, i get an old piece of carpet and lay it under the car. It collects the greasy bits that fly off and i throw it away later. I pre treat with a spray bottle of paint thinner or diesel fuel. Safety glasses and a tyvec throwaway suit and rubber gloves.
Old 11-27-2016, 11:25 AM
