Porsche 935's Avatar
TPS Sensor
Trying to track down my intermittent accell problem. Car starts fine, runs well, fuel mixture good. But sometimes trying to accell fro a low rpm the engine just does not rev up, like the engine does not know the throttle is opening. Could their be a bad spot in the TPS sensor?
3.3 ltr, stock compression, efi, twin turbo - no intercooler.
Old 12-08-2016, 05:57 AM
T77911S's Avatar
it should just be a switch.
you may be able to hear it open and close if you open the throttle....with engine off.
you can check it with an ohm meter,.
should also be adjustable.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 12-08-2016, 06:40 AM
I see the closed throttle switch, it seems to work fine. So the Computer is not using the TPS sensor as a fuel enrichment device?
Old 12-08-2016, 06:46 AM
T77911S's Avatar
maybe at WOT.
it uses the AFM/MAF
but I don't know your EFI.
RACE CAR:: sold
Old 12-08-2016, 07:34 AM
T77911S's Avatar
what about fuel pressures/pres reg
RACE CAR:: sold
Old 12-08-2016, 07:35 AM
This is for my stock 84 Carrera. My other Porsche uses a tec3r set up.
Old 12-08-2016, 07:36 AM
Ken911's Avatar
If its the carrera then the air flow meter is defective. The TPS sensor is just a switch that shuts off the AC and a couple other electrical loads at full throttle.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 12-08-2016, 07:40 AM
