Clutch noise
Hello,
I just bought an 88 911, i bought it from a dealer sight unseen :/ they swore that clutch is fine. When i took delivery, i noticed a weird sound when you release the clutch in reverse/first gear. I cant pin point when it happens (most of the time when u just start in the first it wont make the sound), like when im pulling out/or in. More so in reverse. Hard to describe the sound, almost like a duck call... or blowing into harmonica.. Pls advise. The clutch seems to engage great, all gears work without a hickup. Uploaded the video https://youtu.be/Ul4JV2l6K5A Last edited by EuroZ06; 12-03-2016 at 06:44 PM.. |
Does the car have a Limited slip diff?
Member 911 Anonymous
Take a sound/video clip of it and post it.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Ttt uploaded the vid to the first thread.
It only happens sometimes. |
I had the same noise, it was the take out bearing when it was spinning up. It was only after the car was sitting for a while. As soon when I started driving it the noise kind of went away.
Juergen
'86 Carrera Cabriolet Grand Prix White '09 VW Beetle Convertible ‘24 Audi Q8 etron |
dar636
I cant exactly pin point when it happens, car hasnt been sitting (in my possesion). When i normally drive around town(1st-5th gears), the sound is not there. Its only in tight spots, if im backing into garage in reverse or doing a tight turn in 1st gear |
? Should i worry about this? Does tranny need to come out to fix it?
Under the radar
The engine and trans are removed to access the clutch. I would drive it a while and see if it gets worse. I can't tell when it is making noise. Clutch in or out or just touching the pedal? Does the noise stop when you push in the clutch?
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 12-10-2016 at 03:45 PM.. |
