85eurocarrera's Avatar
Pre muffler question
I believe I have an m&k pre muffler...bought it here used. The one I took off looks to be cheaply made. I noticed my new one has a larger diameter round pipe compared to the one I removed. ~57mm compared to ~49mm of the cross over pipe coming off the car. '85 ROW carrera.
I did a test fit and everything lines up...better than what I had. Do I need to worry about the difference in pipe diameter?
Thanks.
Joe
Old 12-04-2016, 03:53 PM
Checked out
McLovin's Avatar
No.
Old 12-04-2016, 04:03 PM
Member 911 Anonymous
DRACO A5OG's Avatar
You should be fine, if cross over is OEM. Just remember not to over torque the bolts/nuts. Spec is 18 ft lbs or you will warp the flanges and cause a leak. Use new gaskets.
'85 Carrera Targa
PCA/POC
Old 12-04-2016, 04:04 PM
Thanks.
The new piece you aquired is a TRUE premuffler which has an expansion tube part with a baffle in it , your old one is nothing but a Cat bypass PIPE.
Your much better off with the new one, "you done good"
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 12-04-2016, 04:10 PM
