New-ish 911SC Targa Owner
Targa top wind noise
I wanted to check with others that know these things. My targa top is noisy on the passenger side front. above 70mph it gets pretty loud. When the top is on the car, you can see that the vinyl is lifted slightly at one of the folding seams. it doesn't lay completely flat like it probably should. Is this fixed by having a tighter-fitting top vinyl or does it need something else? will a new top vinyl offer some improvement at all?
From looking at it it doesn't seem like there is anything besides the tension of the vinyl to pull it down tight and straight so i'm ready to spend the $200 on a top cover but not ready to spend $3000 to have it completely rebuilt.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
There are 8 small clips along the front edge of the top that hold the vinyl down when attached.
Check that these are connecting. Mine did the same...Pelican sells clips that are slightly longer, to make a better connection...targa top clips. |
Vulnerari Praesidio
Your top is breaking down, and will only get worse as time passes. Call Dan:
www.carsincnj.com Rebuilds usually run $1400
"Wisdom is knowing what to do next; virtue is doing it." - David Starr Jordan Last edited by Roswell; 03-08-2018 at 12:30 PM.. Reason: repairing link |
Fleabit peanut monkey
It's not $3,000, it's just over $1,000 for the all in price for Dan Petchel to do it. If you do the vinyl yourself get the heavier German vinyl.
1981 911SC Targa |
The longer clips as stated by poster 2 fixed mine. Just not enough adjustment available in the factory clips to hold.
Walt 82SC 3.0 81SC 3.6 |
I just got my top rebuilt by Dan and almost all of the wind noise is gone. He does a beautiful job.
$21/Clip is a bit pricey....
'79 911SC Targa |
Wow - $21 each. I'd make sure you need them before trying them! Not really sure how a "better" connection there can help with wind noise but what do I know?! There's another source of wind noise that can sound like it's coming from the top but is actually the a-pillar at the base where it matches the door. If you carefully inspect the seal you'll see where it widens considerably as it makes its way towards the top of the a-pillar. The spot at which it widens must sit snugly on top of the door frame top, when the door is closed. That corner where everything comes together near your side view mirror is a common source of Targa wind noise (I know, I'm dealing with it now and haven't yet had time to replace the seal.) Also Dan Petchel sells the correct seal in the case that you need a new one; I'd buy from him rather than buying the one sold by Porsche/Pelican which needs trimming to fit our cars properly. Good luck! You can get rid of the wind noise and leaks, I've done it! Though it does take time and patience.
Jason - Austin, TX 82 911 SC targa (gone, but not forgotten) 92 968 coupe |
I paid 12.99 in 2014 from another supplier, I don't think Pelican offered the improved version back then. Anyway, I only purchased 2 and that was sufficient to fix the problem.
Walt 82SC 3.0 81SC 3.6 Last edited by walt; 03-07-2018 at 02:57 PM.. |
I had a passenger watch, and at about 25mph the drivers side would lift out of the clips.
Purchased 3 of the longer ones...prob solved. It's been at least 4 years now with no wind noise. I'm sure the lifting is a sign of something else creating the space, but for a cheaper-temp fix, it worked for me. |
Check the length, if buying. |
Vintage Owner
Might not be a bad idea to have someone video your top at speed.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
You need to post pictures on how your top fits. It will help us understand the issues.
In 2012, I had Dan Petchel redo my top. See the results here:
ok, when i have some time i'll inspect the top closer and maybe disassemble it some to see if it looks like the clips and new vinyl would help. If i get too far over my head i can ring up Dan and ship it to him i guess. Don't drive it in the rain anyway so once spring hits top can stay off for a while.
Thanks all!
Senior Member
Have it properly rebuilt. There are two areas that flex when folding the top and eventually they lose tightness and exhibit what you are seeing. There are plenty of temporary fixes but this is not an area for amateurs. For example, you need to do this while it is hot, with the German vinyl, and stretch it using the technique of "breaking" the frame slightly so that when set back you can bounce a quarter off of it.
But the canvas on the underside that holds the frame structure must be in very good condition. the majority of our Targas are not as nobody seems to think the expense is "worth it" compared to other areas. Fair enough if we are talking brakes but otherwise just get it done right so you never have to worry about it again.
'78 Targa in Minerva Blue |
the link to his wesite doesnt work anymore. I had him do my top about ten years ago. and it is needing it again. the florida sun here is rough.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
Dan did mine and it looks great. You dont want the fabric to tear off at speed it could hurt you or someone else
This one works and was also linked in post #3.
1981 911SC Targa |
Exactly what happened to mine after my personal rebuild (before sending to Dan)
1981 911SC Targa |
Wow HarryD, he did a great job on yours. Fits like it should, perfectly. Mine's a little less perfect.
