Gas Lines around tank HELP PLEASE
Car: 1978 911SC Targa
Issue: When I open the "frunk" after the car has been sitting a couple/few day's I smell gas. Not overwhelming but it definitely smells.
So I figure I am going to change the lies in and around the gas tank with new ones. The old ones are still the cloth type.
My question is what size and type of rubber hose should I use?
Do you think this is my problem?
PS I did try the search function. I am seriously challenged when it comes to the search function because I can never find what I am looking for.
Old 12-07-2016, 06:21 AM
dlagerstrom's Avatar
If you are talking about the lines in the trunk for the tank ventilation system they are 9mm id and 14mm od. I would think you want to replace these first as they are likely culprits of your fuel smell. Our host sells 9.5 x 14 smooth and 9 x 15 with the cloth braid like original.
The only other hose besides dedicated lines is the 12 mm ID 18.5 mm OD hose from the tank to the pump. This is a pain to get to as you have to remove the cover from under the car.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 12-07-2016, 09:02 AM
Thanks Dave, much appreciated! when you say you have to remove the cover do you mean the skid pan underneath the car?
Old 12-08-2016, 10:08 AM
Yes. Cover for the steering rack. It is where you will find the fuel pump with connections to the hard lines that run to the engine compartment and one hose from the tank to the pump.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 928
Old 12-08-2016, 11:36 AM
I presume from your post that you are smelling vapor rather than raw gasoline. Regardless, the best source for these lines is from McMaster and Carr. Google them and look for the type that handles gasoline and fuel vapors. They come in bulk and are not terribly expensive. I cannot remember the exact type/brand of hosing; perhaps someone on the board will remember.
Tom
Old 12-08-2016, 12:04 PM
Mark Salvetti's Avatar
You should be able to visually inspect that hose and be able to easily tell if it is leaking. It is always under some slight pressure from the head of fuel in the tank.
This also means you need to drain most of the fuel out of the tank to replace this hose.
Mark
1979 911SC Targa
Old 12-08-2016, 12:22 PM
Thanks all, just to clarify, I am smelling vapors, I do not see any gas leaking from anywhere.
I am going to change the 9MM cloth braided hose first to see if that solves my problem. Will keep you posted.
I just ordered it from our host.
Old 12-09-2016, 06:46 AM
Smoove1010
Smoove1010's Avatar
Unless you've checked the hoses under the car, I'd make it a point to do so. I had similar odor problems when I first acquired my '87, and while I did replace the hose bits in the frunk, I found the chief culprit was that short piece between the tank and the fuel pump. There was no dripping leakage, but the fabric jacket was wet with fuel. Here's what that piece looked like on the inside when I did an autopsy. When a car is this old, all the rubber bits (fuel, suspension, braking, etc.) are suspect.
1987 3.2 911 Cabriolet
Grand Prix White Exterior
Five Shades of Burgundy Interior
Old 12-09-2016, 07:29 AM
rnln's Avatar
I don't know what size, because I got them from my buddy, but they are the problem on my car. Replaced those short hoses (2 sizes) and the smell is much less now. I also replace the fuel level sender gasket but my old gasket still looked good when I took it off.
Fat butt 911, 1987
Old 12-09-2016, 09:30 AM
Smoove, I will check that as well.
Did your line go to metal right inside of the smugglers box? Interestingly enough, I never noticed this before, but there is no clamp on the hose where it attaches to the metal. I will have to add one when I replace it. YIKES.
Old 12-09-2016, 10:18 AM
Does the 87 still have the expansion tank at the bulkhead? Sometimes it is cracked or disconnected causing vapors to escape.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 12-09-2016, 11:19 AM
mine is a 78 and i do not see any expansion tank.
Old 12-09-2016, 11:59 AM
In the earlier cars it was behind the cardboard bulkhead on the driver side.
1991 C2 Turbo
Old 12-09-2016, 01:21 PM
