Any tips for adjusting shift coupler?
I just replaced the shift coupler along with the Ball Cup Shift Bushing at the base of shift lever and the Shift Rod Bushing in Tunnel Behind Shifter on my 1983 911 SC.
Now I need to adjust shift coupler. Any practical tips on this adjustment? Thanks |
Follow the instructions of the shop manual.
I suspect that they might be different for the 915 transmission then they are for the 901 in my car, so I'm not going to offer specifics. Doing it any other way will not work -- trust me. As in most things with the 911, diligently follow the manual and it will work. Variations -- less so.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Member 911 Anonymous
Remove the shifter boot to get a visual of what you are dealing with. Remove passenger side seat, it will help allot to adjust and a helper to hold the shifter in place as you tighten
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
#147 of 2096
There is a video on YouTube.
Put in neutral, loose the coupler, move the shifter to the left and the coupler to the right. Tight the coupler and should be there. At least every time I do it that way works. Cheers.
#147 of 2096 |
try this one in youtube
https://www.youtube.com/watch?v=b3nPONBAaZM |
Waynes 101 Projects has a process.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
I also had to replace the set screw..after I did the coupler
1999 Carrera2 tip arena red 2000 Boxster S tip...arena red ....black 1981 911sc targa...grey mkt.import...Rosewood 1978 911SC, guards red sunroof delete .much missed 73 914 2.0 found in a bunch of cardboard boxes, and brought back from the dead. |
It is a bit tricky. Mine has just one small sweet spot to be just right. I have the fancier aftermarket coupler that has no slop at all like the factory coupler does. Spend time to get it "dead nuts" on.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Here's a tip, Search, there are probably 500 or more posts on this procedure. Not trying to be a jerk, but it amazes me how some do not use that function which works great!
72 911 Although it is done at the moment, it will never be finished. |
porsher
I followed the manual to the letter but the adjustment was off.
I think the defined process steps would work great *if* there was no wear anywhere in the system. I simply made small adjustments based on feel and crept up on the sweet spot.
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
