-   -   Head Leak #4 via Leak Down Test (http://forums.pelicanparts.com/porsche-911-technical-forum/938525-head-leak-4-via-leak-down-test.html)
DRACO A5OG 03-09-2017 12:47 PM
Yeap, I got it. Dang it
KTL 03-09-2017 12:49 PM
I found doing stretch vs. torque that the bolts were not quite into the recommended stretch region. But I suspect the folks at ARP know that 40 lbs, used with their super duper lube, gets you close enough.
If you wanna do it again for the experience, go for it. But probably not necessary.
DRACO A5OG 03-09-2017 12:59 PM
I put your tools away is a safe spot
Out of site out of mind :eek:
Yeah will do again for safe measure :cool: need to learn the proper way
Tori 03-09-2017 01:53 PM
Ya, if you could learn the right way, that would be even better for when you come do mine. :D
Trackrash 03-09-2017 04:14 PM
I love your "clean room". Is your wife out of town?
Yea, good idea to use the stretch gauge. If you lube the threads and if there is not problem with the threads and if there is no dirt on the threads and if the bolts are all up to spec and if your torque wrench is calibrated, then the stretch will be in spec when torqued.
DRACO A5OG 03-09-2017 04:48 PM
Yeah she ain't too happy but she understands :cool:
That's an affirmative, will use stretch gauge to verify torque settings !
DRACO A5OG 03-09-2017 06:14 PM
Verified:
0.0105"
http://forums.pelicanparts.com/uploa...1489111898.JPG
Surprising, for a POS HF unit, but it wasn't typically cheaply priced :eek:
DRACO A5OG 04-07-2017 03:02 AM
3.4L Build Complete
Update, 3.4L Build Complete. Will breakin later today :D
http://forums.pelicanparts.com/uploa...1491558309.JPG
Thank you everyone for your tool loans, experience, guidance and moral support. Thanks Wayne for writing the rebuild book, saved me allot of grief and craziness.
This thread is Officially Closed SmileWavy
Joe Bob 04-07-2017 06:36 AM
Oi, Mazel Tov, Bubee! Drive by, we'll go for a chase....
Tori 04-07-2017 01:32 PM
So jello !
vulcan300 04-07-2017 02:08 PM
Great thread Jim. And you're just in time for spring, at least if you were up here in snowy Canada.
