Member 911 Anonymous
Hey Fellas
![]() So I was diagnosing a sudden power loss issue on acceleration. Did a Compression Test, PSI results, dry/cold 57F ambient: #1 170 #2 173 #3 174 #4 95 #5 160 #6 173 Wet tested #4, PSI went up 5 PSI to 100. Not too happy with #5 either, I can see both head to cam seam appears to be weeping oil ( wet ), nothing at crank. So hopefully rings are intact. The leak down, per OTC instructions: Warmed her up for 20 minutes at 2000 RPMs ( observed allot of popping ), til warm. Removed Oil Filler Cap Removed Air Filter Placed on #4 TDC Connected Leak Down Tester and brought Air Compressor up to 100 PSI, dialed OTC regulator to 90PSI Yay! 58% LEAK (38/90) ![]() No air leaking from Oil Filler, Air Intake Box nor Exhaust, WTF ![]() Wait a minute, I hear air from the Fan Housing, yeah that makes sense, no radiator, so that is our version of a Radiator Leak ergo Gasket or Head Leak ( On Video at 0:23 )Time to drop the engine, Happy Days ![]() ![]()
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 12-08-2016 at 04:04 PM.. |
Now to ponder, Repair, Top End Rebuild or Complete??? Oh the Joy!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Registered Minimalist
It's only money. But sorry to see this man. Hopefully you can turn it into a fun winter project.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Indeed.
Well, I see no gaskets from head to cam tower, so it must be either the sealant gave way or I have cracked head, More Joy
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 12-08-2016 at 04:37 PM.. |
French Import
How man y miles on your 85 Targa?
This may help with your "complete or just top end" decision. Either way I'll meet you on Saturday with the engine stand and yoke. Sorry to hear about your troubles Brother Jim...
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Home of the Whopper
I had the same issue on a 3.0. Took off the head, lapped it to the cylinder, put back together and vroom vroom!! Good luck!!
1968 912 coupe 1971 911E Targa rustbucket 1972 914 1.7 1987 924S |
If you meant by the Valves, oh yeah, it will be sent to professionals for that work :-D
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 12-08-2016 at 07:11 PM.. |
Mighty Meatlocker Turbo
I don't know what to make of your hearing hissing coming from the fan housing other than for a crack in a head or cylinder (would probably have seen a fair amount of oil in that area, though), or very poor sealing between a head and cylinder form a broken head stud, etc . . . Last edited by Rawknees'Turbo; 12-08-2016 at 07:21 PM.. |
^^^ yeap, I am preparing for the worst.
Yes, I have observed allot of oil on top when I had pulled the alternator and recent cam swap on the lower side. At first I thought it was leaking rocker shafts, but nope those were bone dry after swap.
Platinum Member
Head Studs OK?
Miles? Prior rebuild? |
Sorry to see that Jim,..... whens the engine drop party ? I think i have some leftover undrunk (drank?) beer.
1987 911 Carrera Coupe 1987 Buick Grand National 1971 Plymouth Roadrunner |
Head Studs, not sure yet, but I believe so but I will soon discover on tear down.
Miles, allot, over 316,000 ![]() Prior rebuild 150,000 miles ago, I got her at 170,000+/-, Wow I put allot of miles on her since 2005 ![]() Side Bar: I am surprised how well the D-side & #6 compression came out, I thought that side & #6 got more extreme temps, guess not.
Oil Leaks at #4
Brother Dracolio - will be fascinating to see what you find - the oil leakage makes me think broken head stud(s), but those aren't usually associated with sudden power loss (unless several broke at once, which doesn't seem likely). Did you hear a bunch of "pffftttt pfffftttt" noise from the engine the last time you ran it (as in, actually hear combustion leakage while the engine was running)? |
I think I did when power was lost on accel.
Damn.... didn't you just finish overhauling the transaxle on that car? Bad luck. At least you've got the know-how to delve into a project...
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
Home of the Whopper
Basically put some lapping compound around the cylinder, insert cylinder on head, and start spinning back and forth. On my 3.0, I didn't notice any power decrease. But it was in a 2150# coupe. Only indication was a puff of smoke off throttle. Did a leakdown and heard air escaping from the fan. Just like you. When I pulled the head some of the gasket was actually deformed and *leaking* past the head cylinder interface. I will try to find a pic but that was several computers ago. Good luck!!
Oh quite interesting, I never knew you could do something like that.
Outstanding! Quote:
Oh I see, what you mean now:
