Project: Converting a Kiwi Racecar
Greetings, I’ve been away from Pelican and pcars for the last few years as I’ve found myself wrapped up in life, work, more work and an international relocation to Auckland, New Zealand of all places. With nothing to do on weekends I’ve been hunting for a Porsche to get my hands on. P-cars down here are not easy to come by…after clicking “refresh” incesantly on the local equivalent of Craigslist for months, the 1979 SC below popped up. I called, drove out to the country and bought it on the spot. No clue if I paid the appropriate amount but I’m back in the club. Kiwi’s are famous for their kindness, the previous owner was no exception to this true stereotype. Poor guy teared up as he drove way, but has first right of refusal to hit the track with me and he has weekend borrowing privileges when the car is complete
Post purchase inspection didn’t turn up one thing to do or fix. The shop said the car is setup and ready to go. My vision is to turn this into a weekend track car (that I can drive to the track) My Pcar experience is limited to converting a stock 87 and 95 to wannabe race-cars. (mild track-day cars) This is my first time buying a full blown race car with the intent to take it back to street….I’m questioning what I’ve bought and what I should do with it, keeping in mind I know my limitataions as a mechanical moron!!! From what I can tell is on the car.... Fiske 3-Piece Wheels 935 Suspension, looks to be ERP?? JRZ Coil-overs 3.6L Engine, rebuilt 1k miles ago, 1% leak-down on all 6 cylinders, 57k miles on engine. 50MM PMO’s RS Cams Full Cage Fresh 915 with Close Ratio Gears, Race Syncros Racing Clutch New Porsche LSD RSR Exhaust Big Reds Adjustable Sways Atom ECU Facet Fuel Pump Center Mount Front Oil Cooler I’m thinking I want to backdate it to a 911R and reasoning with myself that I might as well backdate it now? To get it street legal I need to reinstall the wiring for the headlights, turn-signals, install a horn, washer fluid tank etc. Since I need to put all this stuff back which is a project in of itself, I might as well get the backdating out of the way and do it now. Does that logic make sense from a cost standpoint? After reading countless backdating threads I’m more lost than when I started. Can someone suggest the most cost effective approach to backdating this thing? Shipping parts over here is insanely expensive and body shop labor seems reasonable. I’ll do the interior myself as the car does not need to be anywhere near concourse. I’ve always wanted a 3.6l rat rod of sorts. Thinking metal extensions on the existing front fenders, graft in some metal turn signal frames, go with a fibreglass R type bumper (with drilled vent holes for the front oil cooler) Fiberglass 4-pin long-hood since the plates are already installed. With a little luck I’ll embark down the road of backdating assuming I can do it for under $7 or $8k anything more than that and it will be a stretch. Anyway looking for advice, thoughts, warnings etc. I’ll keep you all updated on my progress with with this! Thanks, Dan ![]() ![]() Big Reds, ![]() JRZ ![]() ERP Part? ![]() 935 ERP? ![]() Spring Plate...ERP? ![]() ![]()
It looks awesome as is. Don't backdate..
'82 911 SC IG: @rywats |
Looks like a great car with a lot of VERY nice bolt-on go-fast parts.
If you decide to backdate it, there is a fiberglass long hood that you can use that will work with the front latch panel on your car. Using it would allow you to get the long hood look using bolt-on parts (thus easily reversible). Try TRE Motorsports in Southern California. They most likely could put together a parts package for you & ship it in one box...
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
+1 .... Give Dave at TRE a call and he can set you up with everything you need to backdate it if that is the route you decide to take. However it looks great as it sits. Congratulations!!
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
+ 2 Don't back date it. It looks fantastic the way it is!
For street you'll likely need to spend money on suspension and sound mitigation. Or better yet do nothing and give her a go on the track. Last edited by Mister e; 12-10-2016 at 10:15 PM.. |
Thanks for the help, I was thinking TRE was the way to go from what I could gather. 2 votes to keep as is, I'm so easily swayed maybe I'll leave it be and drive it for a year before backdating. I'm itching to get this thing out on the road.
You nailed these two items. The exhaust isn't insane but the flywheel and engine noise is nuts in the cabin. Hoping a sound pad in the engine and in the interior should help. I've read that the JRX's will work great on street but I need to install some softer springs. Figure I'll chip my teeth for a month and see what a proper racer is like like to drive and then soften it up if I can't take it. |
Taking advantage of some of your knowledge as I've been out of the game for so long. Curious what you guys think of $44k us for this car? After pricing out the list of parts it seems like a decent price for a straight fresh engined car. No doubt you pay a premium over here but $44k seems good, not great? Trying to sleep better at night and knowing I paid too much or too little will help so long as I know.
RETIRED
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
RETIRED
Dumping the wing might upset the aerodynamics with that front end treatment.....just sayin'. Test it speed to see if it gets squirrely....
**** its good to be talking about this stuff again. |
RETIRED
I'm sure you will find out when you take the wing off. So, don't sell it (borrow a stock lid) until you test it.
BTW, I used TRE glass backdate stuff. If you can get a deal on shipping, he's the guy.
Awesome. Keep as is and drive the crap out of it
Sent from my iPhone using Tapatalk |
the 935 suspension bits look like they are from The Racers Group, basically a copy of ERP
phase 9 mufflers lots of nice parts on that car |
Dan |
She is officially back to her preferred place on all 4's.
Lights installed, seats in. Next stop is suspension shop to insert new Rebel Racing bit and pieces. ![]() ![]()
oh, wow, missed that!
looks like a really nice outlaw now! maybe you might mitigate that front bumper to a less agressive style to harmonize it with the rear to finish the look?
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Agree with you, the front bumper isn't right. I have a front mount oil cooler so I need to find something to work around that. Ideally someday I will backdate it and copy the Singer style cut out they use. Beyond that I don't see many other options other than a Blackbird which I'm not a huge fan of.
