jjonesx86's Avatar
Can you help identify what these holes in the floorpan might be?
Hi,
When I bought my 87 911 Cabriolet the PPI called out some strange holes/gromets that run down the center of the floorpan. I had it up on a lift for the first time and was able to take a quick photo.
Does anyone recognize what these might be?
Thanks,
Jeff
2024 Spyder RS
1975 930 Turbo
www.chassis106.com
www.911maniac.com
Old 08-12-2014, 09:09 PM
RaketeRot
Draden's Avatar
Do you have any unusual attach points up front or in the rear. Say like a oil cooler addon that was removed or some signs of a past electrical mod in the rear that needed wires route back to it?
Maybe some holes into the pan up front to pass something thru where the anchors stop?
Why I ask is I've seen many people just route wires or hard lines under a car instead of doing a proper routing thru the shift tunnel
Looks to me like those are anchors for clamps for something that was a afterthought running fore or aft.
1967 911R hybrid clone
1973 911 RSR - coilovers, 2.8L twin plug RSR cam engine. butt welded metal RSR flares and metal frame ducktail
If it were easy, it would not require people of our caliber.
Old 08-12-2014, 10:24 PM
Send a message via Skype™ to Porboynz
Its a cabriolet, must be to let the water out?
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 08-12-2014, 10:32 PM
Just a guess, has your AC been removed? Those might be the grommets for the clamps that ran the condenser lines?
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 08-12-2014, 10:39 PM
jjonesx86's Avatar
There are not any signs of anything odd having been installed and nothing factory has been removed that I'm aware of. All AC lines are there and working.
I hadn't thought about the possibility of these being drain holes for rain water. It would seem odd that they would run all the way down the middle like this but maybe? Any other Cab owners have something similar?
Thanks for the ideas. It's just a curiosity for me.
Jeff
2024 Spyder RS
1975 930 Turbo
www.chassis106.com
www.911maniac.com
Old 08-12-2014, 10:50 PM
ROW '78 911 Targa
timmy2's Avatar
Any indications this car has been in an accident requiring it to go on a frame machine?
Could they be alignment points for straightening the chassis on a Celette?
Never having seen the device in use I wouldn't know for sure, but I thought I read a similar post indicating this as a possibility.
Old 08-12-2014, 11:25 PM
jjonesx86's Avatar
I had the car put through a complete PPI and once I took possession it spent some time at a Porsche specialty body shop getting a detailed exam and the boxed rockers swapped for standard 930 rockers. No indications of any kind that it has been in an accident. Clean title / Carfax as well although that can't always be trusted.
2024 Spyder RS
1975 930 Turbo
www.chassis106.com
www.911maniac.com
Old 08-12-2014, 11:32 PM
ROW '78 911 Targa
timmy2's Avatar
Did a quick search for body plugs and Celette.
May just be factory assembly holes that are plugged.
No idea really what they are.
Old 08-12-2014, 11:37 PM
jjonesx86's Avatar
I have done additional searching and when I do a Google image search for Porsche 911 plugs center floor pan I can see other 911 floor pans with the same series of plugs. Several sites seem to refer to these as drain plugs so I'm assuming they are there to drain out any water. It seems strange that they would be on some cars but not others.
2024 Spyder RS
1975 930 Turbo
www.chassis106.com
www.911maniac.com
Old 08-12-2014, 11:44 PM
Michael - 69E's Avatar
Have the same on my '77. Previous owner made the holes for rust-proofing of the tunnel.
Michael
Blut Orange 911 E, 1969
Indisch Rot 911 Carrera 3,0, 1977
Alfa Rosso Alfa Romeo GT Veloce, 1967 (SOLD )
Old 08-13-2014, 12:03 AM
My 70 coupe has them since new from the factory. A friend's 70 coupe also has them. What they are for is anybody's guess. My friend is missing a few. If anybody finds a source for them or a part number let me know.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 08-13-2014, 03:34 AM
Heck, I’m only 5 not 71!
targa80's Avatar
Cool
In my opinion, they are factory made drain holes that are directly under the shifter tunnel. The SC chassis is a galvanized body and that probably required a dip tank after the major body parts are welded together.
This is a pic of the underside of my 80SC just after primer and you can see the series of holes.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 08-13-2014, 03:39 AM
Classic's Avatar
+1 drain holes for when the dipped the frame
Classic 1969 911T
Old 08-13-2014, 02:17 PM
Your car was once connected to The Matrix!
These are the residual jacks.
seriously though I also have them on my 88 and they are factory.
Old 08-13-2014, 02:37 PM
Banned
My 1987 Turbo has the same holes & plugs.
Old 08-13-2014, 02:54 PM
proffighter's Avatar
same here, factory for sure. Look into PET, found 8 plugs there
Roland
930 Turbo '81 Too many modifications to list
Old 08-13-2014, 04:21 PM
Bill Douglas's Avatar
For a hair drier, or color and cut?
Old 08-13-2014, 05:14 PM
I believe the floor plugs are stock. Not sure what they are used for and why they are not on all 911's.
They can be purchased here:
(New) 911 Floor Stopper Plug - 1974-89 | Aase Sales Porsche Parts Center
Lou
Old 08-22-2014, 06:07 PM
Originally Posted by Classic View Post
+1 drain holes for when the dipped the frame.
Porsche dipped the TUBS at the factory, early cars in primer, later cars (70's) in electro galvanizing and then primer.
Those are drain holes. Should have plugs in them.
Old 08-23-2014, 10:05 AM
RETIRED
Joe Bob's Avatar
Speed holes.....
2012 ML350 3.0 Turbo Diesel
Old 08-23-2014, 11:20 AM
