beepbeep's Avatar
Post Reason to change hub? (pic)
Mech teared down front right wheel (in order to change bearings) and found out that somebody (previous owner?) did some sort of reparation and welding on hub, probably due to previous bearing failure. He said that hub must be perfectly smooth in order to accept new bearings and that i shouldn't drive out of shop without new one (to the tune of 450$/hub for used one)...which i accepted.
Here's the pic of hub and it makes sense to me to change it. And it's factory dealership...so they don't want any shoddy work being done.
What do you think?
Cheers!
Old 10-18-2001, 06:20 AM
T Bird's Avatar
Post
Agreed- hubs are a "safety" item. Failure of the hub or bearings at speed could lead to catastrophic consequences. I would have done the same.
John
1972 911T Coupe
"S" pistons & Webers
PCA- Potomac Region
Old 10-18-2001, 06:50 AM
Post
doesn't look good. they go for about $150 to $250 used around here. 1-1.5 hours labor to swap.
[This message has been edited by john walker's workshop (edited 10-18-2001).]
Old 10-18-2001, 07:05 AM
Early_S_Man's Avatar
Post
That isn't a hub, it's the axle attached to the strut ... and I don't see any evidence of welding on the axle, just discoloration from an overheated bearing. A closer pic of the axle with less dust shield would help a lot!
Discoloration of the axle from a siezed/overheated bearing is pretty common, and it doesn't get the axle anywhere near hot enough to weaken it! That axle is bigger/stronger than most US 1/2-ton pickup trucks of the past 50 years, and the loading on the front end of a 911/930 under any condition, even 200+ mph in a CTR at Nurburgring ... doesn't present any danger of failure of that axle! Granted, a bunged-up axle like that does present problems in installing new bearings!
Unless you have more convincing evidence than that pic, you were HAD, and CONNED by the mechanic!
Just as John Walker told you two days ago ... a used strut would have been fine!
Warren Hall
1973 911S Targa
1992 Dodge Dakota 5.2 4X4 parts hauler
Old 10-18-2001, 07:08 AM
beepbeep's Avatar
Post
Yepp, it's a axle on my 930.
OK, i believe they teared down the axle and found out that it previously suffered from overheated bearing. Whoever changed bearing that time used file to smooth out the axle so he could get bearings on.
I agree, it might not be big thing but that wheel sounded pretty weird, so it might be the outer bearing that wasn't sitting perfectly parallel to inner bearing...which induced bearing failure in this case. Pads were unevenly worn too.
Here's another pic of axle:
Old 10-18-2001, 07:20 AM
beepbeep's Avatar
Post
Actually i don't know exact price ... he just said axle itself cannot be changed and i would need new assebmly...but he managed to get used one.
Ahh..what the heck, if i fix this now i won't need to worry about it for a while
Old 10-18-2001, 07:25 AM
Senior Member
orbmedia's Avatar
Post
A brand new strut assembly for a 930 costs around $425 from Pelican parts, even less if its the '89 model. ($333)
So the price quoted for a used part is not right.
Old 10-18-2001, 10:35 AM
dtw dtw is offline
GAFB
Post
I picked up a used strut/spindle (which is what you need, why does everyone keep calling it a hub???) from Parts Heaven for $60 USD. 50 bucks alignment, 2 hours labor...that's under 500 for repair of a not-uncommon part. You need a second opinion. Sounds like your "used part" that the dealer found is being marked up about 6 or 7 times.
-d
Dave
'72 911T to '73 RSR Replica Project
Old 10-18-2001, 11:45 AM
Senior Member
Post
Hello
Turbos have the Bilstein struts and they are not cheap even used they got there price.
Now the ring for the seal lip is separate and can be renewed.
I would have changed it too.
Grüsse,
Roland
Old 10-19-2001, 09:05 PM
