-   -   Installing airplane engine in 911 (http://forums.pelicanparts.com/porsche-911-technical-forum/940441-installing-airplane-engine-911-a.html)
octanemaestro 12-27-2016 12:34 AM
I've searched the web for this and also searched all the forums on here and haven't found anything. I know that Porsche developed a short lived airplane engine based on the 911 engine and produced about 80 units of the Porsche PFM 3200. Has anyone ever heard or seen an installation of any aircraft engine in a 911, the PFM 3200 or otherwise? Setting aside authenticity for a moment, any technical reason why someone wouldn't wouldn't use say an aircooled Continental horizontally opposed dry sump 6 six-cylinder if they had an engineless 911 and an extra low hours airplane engine of comparable size, weight and horsepower to the original 911 engine? Seems like it would fairly simply shoehorn in and run pretty much the same, maybe it would even run better or be better somehow. Certainly it would be better than no engine at all!
http://forums.pelicanparts.com/uploa...1482830770.JPG
http://forums.pelicanparts.com/uploa...1482831104.jpg
http://forums.pelicanparts.com/uploa...1482831104.JPG
winders 12-27-2016 12:52 AM
You mean other than the fact that those Continental engines were low RPM (2500 RPM) engines that were not designed to be used over a large RPM range? How would you cool it? You would need to come up with some kind of fan setup.
Crazy idea.......
octanemaestro 12-27-2016 04:57 AM
Surely there's an airplane piston engine that can be dialed up to 6,000 RPM, somewhere. I'm very curious about this. Many experimental aircraft have used modified dual-plug dual ignition redundant VW flat engines for the longest time. I realize that's going the other direction -- i.e., high RPM to low RPM from car to aircraft, not aircraft to car -- but on the surface this just doesn't seem like a crazy idea to me. It was crazy to make a jet powered Chrysler but they did that anyway at headquarters in Detroit, and this would be a far more modest target for an individual garage.
JackMan 12-27-2016 05:01 AM
Conti engine just won't work in a car. Those engines are made to be cooled with forced air -- period. Never mind the issue of the low rpmz.
HorstP 12-27-2016 06:51 AM
are you at all aware of the displacement of an aircraft engine? A common 6 cylinder engine would be called O-540. And the 540 stands for the displacement in cubic inches....
GH85Carrera 12-27-2016 07:48 AM
Nothing is impossible, but it would be a huge waste of money and time. The RPM issues is the big first issue to overcome. Then cooling is the other. You can build a monster 911 engine that will work great for way less money than re-inventing the wheel. And have you priced an airplane engine?
We just swapped the engine on our 206 non turbo and it was way way way more than my 911 engine rebuild cost. Way more expensive.
octanemaestro 12-27-2016 07:52 AM
Originally Posted by HorstP (Post 9409907)
are you at all aware of the displacement of an aircraft engine? A common 6 cylinder engine would be called O-540. An the 540 stands for the displacement in cubic inches....
What...is that some kind of knowledge test?
I don't know what you are you trying to convey by writing, am I "even" aware. I suppose that's some kind of thinly veiled insult. There is no place for that here, a community focused on mutual help and sharing of knowledge. How is the displacement relevant and the horsepower is not? In fact, how is the displacement relevant at all?
PatrickS 12-27-2016 08:04 AM
A JATO unit would be more fun
http://www.ronpatrickstuff.com/image...en1_PScopy.jpg
tobluforu 12-27-2016 08:06 AM
Anything is possible, just don't get to close to the back of this one.
https://www.youtube.com/watch?v=yGeSIM_8BHY
aschen 12-27-2016 08:08 AM
I worked at continental motors for a summer as an intern. It was a fun experience. I think the motors arnt really suited to cars for alot of reasons. But with enough work Im sure you could make it work. I think the engines are significantly bigger, or at least alot longer than a Porsche flat 6. Each piston/cyl is around 1.5 L. I think a 4 cyl might have a better chance of fitting.
The engines are around 300 hp @ 1800 rpm so that is something ~ 600 ftlbs. Your gonna need a 930 transmission for sure.
I think a more interesting challenge would be to get a porsche to run on a radial engine. Lemons racing allows and unlimited budget for radial powered cars.
stephen1070 12-27-2016 08:27 AM
Everyone should own an airplane engine powered car!
Bob Petersen Engineering | Custom vintage coachbuilt cars | Devon UK
cgarr 12-27-2016 08:34 AM
hell ya do it!!
https://youtu.be/FSzGZh__BuM
Jim2 12-27-2016 08:43 AM
Though somewhat neck in neck price wise the Porsche (auto) engine has a slight advantage to certified aircraft engines, not to mention all the engineering it would take. Oh, and there ain't no bellhousing attachment on the drive end of an aircraft engine!
nota 12-27-2016 09:51 AM
my dad scratch built a aircraft motor powered car in the 40's
based on his war work on the B29 front nose wheels
that could move the B29 by hydraulic motors
the car used a hydraulic pump on the aircraft engine
and driven motors in the wheels
it had no gears
no brakes but had accumulators for regen-braking
no driveshaft
Ford hired him to develop the systems
<a href="http://smg.photobucket.com/user/aarmed/media/img025.jpg.html" target="_blank"><img src="http://img.photobucket.com/albums/v643/aarmed/img025.jpg" border="0" alt="aircraft motor hyd car photo img025.jpg"/></a>
tank accumulator on top pipe and valves lower bit
<a href="http://smg.photobucket.com/user/aarmed/media/img022.jpg.html" target="_blank"><img src="http://img.photobucket.com/albums/v643/aarmed/img022.jpg" border="0" alt="plywood body hydrolic drive frame photo img022.jpg"/></a>
motor in car
<a href="http://smg.photobucket.com/user/aarmed/media/img024.jpg.html" target="_blank"><img src="http://img.photobucket.com/albums/v643/aarmed/img024.jpg" border="0" alt="hyd car motor photo img024.jpg"/></a>
space frame before motor mounted
<a href="http://smg.photobucket.com/user/aarmed/media/img021.jpg.html" target="_blank"><img src="http://img.photobucket.com/albums/v643/aarmed/img021.jpg" border="0" alt="plywood body hydrolic drive frame photo img021.jpg"/></a>
Flieger 12-27-2016 10:08 AM
Why? A turbo would get you the same power with less trouble. It can be done but aircraft engines are designed for very different duty than car engines so it will be a lot of work and at the end of the day you have taken an overhead cam air-cooled flat 6 and replaced it with a pushrod air-cooled flat 6. Not that different and certainly no more exotic. Is the 540 cubic inches worth the hassle?
HorstP 12-27-2016 01:56 PM
There was no intention to insult you. But the idea is so far from being practical that I did throw in that argument. I had hoped that pointing out the fact that a 6 cylinder aircraft engine has in pretty much all cases more than 7 liters displacement is already a hint that it has no practical value to discuss this. Displacement is of course relevant as it determines how big and heavy such an engine is.
Displacement aside, the biggest topic, as already raised, is the fact that a bigger aircraft engine is designed to run at a fixed rpm setting. Smaller, 4 cylinder engines coupled to fixed props do run at different rpms, but bigger engines, specifically the 6 cylinder ones, are in almost all cases running with a constant speed prop, so rpm stays constant but the propeller is adjusted. A typical IO-540 motor runs at around 2200 rpms and produces about 225 hp as rough indication. (I stands for injected, O for opposed, H would stand for the use in a helicopter).
Another indication on the shear size of piston and cylinders: an aircraft engine cannot /should not simply turned off. After landing, it needs to run typically another 2-3 minutes to cool down. Once the cylinder head temperature has dropped and stabilized, only then it will be shut off.
The fan required on an air-cooled aircraft engine is quite bigger than the fan of a 911 engine, it is a big piece of metal. Fixed wing aircraft don't have a fan as they just push air through the cowling but helicopter versions do need the fan.
And no aircraft engine will withstand 6.000 rpms. One of the higher turning engines, a HIO-320 runs at 3.200 rpms. We had somebody overrev it by 10% for 30 minutes, engine was toast after that. Almost all valves bend.
So bottom line, forget it...
Trackrash 12-27-2016 02:02 PM
If you want huge horse power go with a gas turbine. 6000 HP. Not much bigger than a piston motor.
https://en.wikipedia.org/wiki/Lycoming_T55
HorstP 12-27-2016 02:10 PM
as a matter of fact, a turbine with comparable HP is much lighter than a piston engine. I can lift a turbine producing 400hp. But yet again, same problem, they run at constant output rpms (the gas producer runs a variable rpms depending on the load)
gtc 12-27-2016 02:17 PM
I dunno. I think you would have to upgrade to a G50, or at least 108mm CVs. Sounds like a hassle.
winders 12-27-2016 02:37 PM
Read post #2 again........../thread
RichardNew 12-27-2016 02:52 PM
The OP has the right idea. This car/airplane engine has been done more than once.
http://forums.pelicanparts.com/uploa...1482882635.jpg
http://forums.pelicanparts.com/uploa...1482882679.jpg
A few years back I was staged in back of a jet dragster. Now that was an experience.
Richard Newton
ClickClickBoom 12-28-2016 12:09 PM
Use Tesla style running gear and a gas turbine running a generator.
Been wanting to do this for years in an aircraft, gas turbine running a generator, attached to a glider, altitude record for electric powered plane.
All I need is a huge pile of someone else's money.
Canada Kev 12-28-2016 02:30 PM
Just use a radial. It'll fit, no problem... ;)
http://forums.pelicanparts.com/uploa...1482967820.jpg
https://www.youtube.com/watch?v=GjRwxNX6Q_o
Canada Kev 12-28-2016 02:39 PM
And people have put turbines in motorcycles even - Leno's got one.
https://www.youtube.com/watch?v=t0KjVz6uSS4
http://forums.pelicanparts.com/uploa...1482968375.jpg
Autoban 12-28-2016 03:11 PM
Originally Posted by Canada Kev (Post 9411668)
That is pretty impressive (and funny). The guys have to wear (David Clarke) headsets because of the noise of the engine. I wonder if they installed an aviation intercom as well. If it is a 7 Cylinder (looks like it) from a Cessna then it is most likely a Jacobs radial engine from a C-190 or C-195 with either 275HP or 300HP. At "cruise" setting (I believe somewhere around 2,100 RPM) the engine will burn 14 to 15 Gallon per hour.
Juergen
winders 12-28-2016 03:25 PM
https://en.wikipedia.org/wiki/Jacobs_R-755
Canada Kev 12-28-2016 04:59 PM
Juergen
I think an Intercom is installed, if for no other reason than what you said, the incredible noise. I also saw another video that must have had a feed from the intercom as he could be heard quite well.
The owner said the mileage was about a gallon per block. Certainly not gonna win any accolades from Greenpeace...
Trackrash 12-28-2016 05:13 PM
Since we are talking aircraft motors. Has anyone ever seen this truck? 3 Pratt & Whitney J34-48 jet motors.
Shockwave.
http://forums.pelicanparts.com/uploa...1482977599.jpg
Joe Bob 12-28-2016 05:22 PM
They put a Spitfire motor in a Bentley.....
http://forums.pelicanparts.com/uploa...1482978134.jpg
dafischer 12-28-2016 05:39 PM
Yep, V12 Merlin into a Bentley and a Rolls.
http://forums.pelicanparts.com/uploa...1482979056.jpg
http://forums.pelicanparts.com/uploa...1482979090.jpg
Joe Bob 12-28-2016 06:20 PM
They took the governor and turbos off. They handle like a 10 tonne truck but go like shyte in a straight...
stownsen914 12-28-2016 06:26 PM
It might hurt the resale value of a 911, but heck, if it makes you happy, go for it! If you do it, please post a few pictures ...
flat6pilot 12-28-2016 10:36 PM
Air-cooled GA engines are built to looser tolerances for better reliability at low RPMs. Spin them above 3k for any extended period of time and you will probably lose the reliability advantage.
The Piper Arrow I fly has a max continuous limit of 2700 RPM (@~200hp). Controlled by an adjustable pitch prop.
And they only hold a max of 8qts of oil.
But, I'd love to see you try and what solutions you come up with. I'm sure it could be done....somehow. The only reason the aviation engines cost more to rebuild is because they're...well, FAA regulated mechs $$ working on them. Everything's a lawsuit once you're airborne. If you did the work yourself you may not have that issue.
safe 12-29-2016 02:10 AM
Continental in a vw:
https://www.youtube.com/watch?v=J4IzSXvUoyc
Fast Freddy 944 12-29-2016 07:03 AM
Why not just go down to a local airport, learn how to fly, get your private pilots licence, and save money on destroying a good Porsche and a Cessna or piper in the process.......
Joe Bob 12-29-2016 07:24 AM
The W 12 was a very popular Pre WWI engine that was modified for many subsequent uses. https://en.wikipedia.org/wiki/W12_engine
Quicksilver 12-29-2016 07:41 AM
HorstP pretty much covered most of it in his post but to add a few things...
To quote my ground school teacher in high school, "If we put an airplane engine in your cars all of you would seize them in a week with all your getting in and revving them and driving them before they warm up." (Yes. Ground school was a course in my high school!)
An air cooled engine designed for operation only with a careful check listed startup, regular tear down based maintenance, fixed low RPM operation, and cooling from a completely consistent high speed air source coming from the direction of the crank flange instead of from above.
Water cooled engines will let you have a bit more wiggle room but the fact is it is a lot easier to adapt an automotive engine into an aircraft then the other way around.
- Oh and a turbine is no cake walk. Find Leno's video about what he had to go through designing his "Jet car". An engine that idles at 80% of full RPM is not easy to use in a wheel driven car.
dicklague 12-29-2016 08:41 AM
Correct me if I am wrong, but was it mentioned why Aircraft engines are designed for lower rpm??
The speed at the tip on the propeller is the limiting factor. When the propeller tip goes over the speed of sound it loses lift and becomes way less efficient.
Aircraft engines are designed for much lower speeds than and automotive engine.
fbarrett 12-29-2016 10:40 AM
Here's a shot of the circa-1960 Porsche 678/4 aircraft engine that Dennis Frick (Europa Macchina) restored for me a few years ago. I found it in Trade-A-Plane. It was set up on a portable stand, and we ran it at the 2009 Parade concours. Twin ignition, dual fan belts, gear reduction unit (about 50%), dry-sump lubrication, etc.
http://forums.pelicanparts.com/uploa...1483040335.jpg
Frank
proffighter 01-05-2017 03:14 AM
My Turbo has an 930/67 aircraft engine (at least crankcase)
