What flares are these and best wheels to fill?
I recently got a 1974 911s targa with metal flares welded on
some years ago ![]() They extend about 2 inches past the 205/55/16 on 7 inch rims. My question is there a name for these flares, ie what model were they trying to copy? Also, I would like to bigger wheels and tires to fill up more of the flares without using spacers. Any suggestions on tire and wheel size (8 inch?) and backspace? Thanks Glenn in San Diego |
Looks like standard Carrera flares to me. You could go 8 inch in the rear no problem. Tim
Put some 8x16 Fuchs on the rear and move the 7x16's to the front.
Thats ALL you need, aside from a proper corner balance and alignment.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Member 911 Anonymous
+1 Standard Carrera
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Pretty color. What is it?
gearhead
This. Exactly what I do with my flared 74 in the summer.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Thanks so much
It appears the front ones are 7 inch as well with 205/55/16 tires Forgive the newbie question, but if I go with the 8 inch Fuchs in the rear, is there a standard backspace they come in? Or do I need to specify a backspace? Where do I get them that would match the ones I have up front? What tire size? As far as the paint, it was originally yellow, then red, maybe black and finally the worst grey paint job you have ever seen. They sprayed over the plastic rock guard before the rear arches. Obviously once I get this thing running we are going down to metal. |
I didn't see the poor quality of the paint until you pointed it out.…kinda like those Magic Eye books.
As long as the 8" Fuchs you buy have a part number beginning with 911, you don't need to worry about the offset or backspace. There's a version that has a part number beginning with 951, you don't want those. Use a 225/50-16 tire.
JR |
This shows the max f/r front and back space fror some wheels and sample tires ![]() rule of thumb w/ stock SC/Carrera flares rear can fit 9.5ET19 w/ 255/40 tires as long as the tires are ~25" or less OD, stock max would have been 8ET10.6 as JR says any 911 part# 8 will be fine either 15 or 16" w/ 225/50 tires. Lots of guys use 9ET15 w/ 245/45 x16 these were oe on late 930s. Custom wheels 17 or 18 up to 9.5ET19 will fit to, but tire choice becomes critical, I've used up to 275/40 x17 and friends up to 285/30 x18 but larger than 255/40 x17 will require lots of dditional work and restrictions on ride height. The kicker here is that w/ weld on flares you may have more or less clearance than was available oe. It all depends on what the body guy did.
The tires on the car are bad so I don't want to buy tires for that I won't be using for long. Thanks also for the fitment chart above Glenn |
JR |
Would these work with this offset?
Euromeister Alloy Replica Wheels, 17x8, (ET 10.6 offset) |
The offset is fine but I wouldn't run a 17" wheel on that 911, nor would I pair it with the 16" fronts that you already have.
I'm not a fan of aftermarket, fake Fuchs, either. JR |
Oops, wrong wheel
Euromeister Alloy Replica Wheels, Semi-Gloss Black w/ Machined Lip, 16x8, (10.6 offset) If I went with aftermarket I would need to get all 4 so they would match Having trouble finding 16x8 Fuchs that are readily available. I need to get the car driveable. I may just have to get cheap tires for the 7 inch rears as a temporary solution until I can get the proper rear rims |
I will give them a call |
