Rebel racing front bushings
Planning to buy a set. Pros and Cons ?
Old 01-03-2017, 07:52 PM
tscrihfield's Avatar
I've use Clints front bushings on 2 cars. The only downside for me has been contacting Clint. Otherwise his products are top notch!
Old 01-03-2017, 07:56 PM
Max Sluiter
Flieger's Avatar
Working great for me.
Old 01-04-2017, 08:18 PM
Working great for me as well.
Old 01-04-2017, 08:31 PM
scottrx7tt's Avatar
I have them and am picking up some squeaking from time to time.
Old 01-04-2017, 08:35 PM
$ Short's Avatar
I run these on 2 cars. I would recommend these as well as rears.
2010 Carrera S
GONE
2022 Cayman T
2007 GT3
1988 Carrera
Old 01-05-2017, 07:39 AM
Have them on both my cars... very happy with them..top quality products..!
Old 01-05-2017, 09:17 AM
non-whiner
mreid's Avatar
Have them front and rear. Highly recommended!
"Too much is just enough."
Old 01-05-2017, 05:39 PM
vansicklenmi's Avatar
So you are saying that he should consider different products?
Old 01-05-2017, 05:59 PM
SoCalSK8r's Avatar
I am running fronts and rears on mine and I love em.
‘84 Carrera, heavily modded
Please follow me @chopped_up_fitness
Old 01-05-2017, 09:37 PM
Top quality components. Take the time to test combos of spherical washers to find the set that gives the lower control arm optimal free swing - ensures long & quiet life.
Old 01-05-2017, 10:20 PM
I'm right there with you 911 slant.
My front suspension is presently dismantled and I'm leaning towards the Rebel products. I've been reading all the threads on suspension rebuilds and vacillating between the Elephant rubber or the Rebel product.
The Elephant rubber appeals to me due to keeping it near stock, less harshness, and potential ease getting it back together. (My car was damaged by a prior owner and been repaired. I'm concerned it may have some "tweak" in the front end)
The Rebel product is more precise and from what I've read offers more compliance. Do it once and forget about it? I hope so but in dismantling the my suspension I've found road grime everywhere and I'm concerned how the rebel product's interface between the pivoting suspension points will withstand the elements and time.
When I removed the factory bushings, the rubber was still pliable but had definitely taken a set. Hence, the Elephant product will eventually also need to be replaced.
Let us know what you decide.
Tinker
Old 01-06-2017, 09:10 PM
Are the Rebel bushings Derlin?
1979 SC
1986 Carrera 3.6 L+
Old 01-06-2017, 09:15 PM
Max Sluiter
Flieger's Avatar
No
(by the way, the correct name is Delrin, a trademarked name like Teflon. Generic it would be acetal or POM (polyoxymethlyene)) The Rebel bushings are not Delrin either.
Old 01-07-2017, 10:51 AM
Running front and rears here! Happy customer Placed the order online and they showed up a week later.. didn't bother calling, but have heard he is difficult to get a hold of. Not in my case though!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C
Old 01-07-2017, 01:00 PM
get the ER sphericals. No support issues and probably even a better product
Old 01-07-2017, 01:35 PM
frankc's Avatar
I'm running ER Sphericals up front, and Rebels in the rear. I have about 1500 miles on this setup, and I'm very happy with the result so far.
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 01-07-2017, 08:57 PM
BFT3.2's Avatar
Rebels front(w/conical washers) and rear for over a year, no issues.
Cons: IF you have a G50 with the longer rear torsion bar spring plate "tubes", you MAY have to remove some material on the tube in order for the race to slide over the entire tube to where it comes to final position against the spring plate. My spring plates with the torsion tube had to be put on a lathe and disc sanded down a hair. The micrometer showed that the torsion tubes were a hair larger in the middle then at the ends where the race fits perfectly.
______________
'88 911 Coupe
'98 Spec Boxster
'85 380SL Benz -Euro
Old 01-09-2017, 10:47 AM
Old 02-13-2018, 04:59 PM
More pictures tomorrow. Just did a dry fit before JB welding the race flanges
Old 02-13-2018, 05:15 PM
