Roger 911's Avatar
'84 Carrera faulty DME?
I have a '84 Carrera motor. Car has been sitting for about a month. Ran/started fine before it sat. Won't turn over now. Confirmed that when trying to start, there is no power being sent to either the starter solenoid, or the fuel pump. Swapped DME relay, no change. Originally thought it was faulty ignition switch, swapped that, no change. I'm thinking it might be the DME itself.
Any other suggestions?
Roger
'72 911 3.2
'18 Mustang Eco PP
'17 Mustang GT Conv
Old 01-21-2017, 11:28 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Battery.
Roger
Let's start with the "simple" stuff first.
1. Battery cranking voltage/amp check.
pm me as needed.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 01-21-2017, 11:49 AM
Diss Member
Quicksilver's Avatar
The DME doesn't power the starter solenoid so you have somewhere else to search. Obviously you need to have 12 volts from the battery cable at the starter but that would be hard to break.
I would start by checking at the starter switch to make sure it has voltage in and the starter circuit switches on when the key is turned.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 01-21-2017, 11:50 AM
Roger 911's Avatar
I guess the fuel pump won't run if the starter isn't turning the engine over, since the DME needs to see RPMs before it will power the pump. So the real question is just why am I not getting power to the yellow wire that activates the starter solenoid? I know the solenoid works, because I powered it directly and it does work. Just no power getting to that yellow wire.
Roger
'72 911 3.2
'18 Mustang Eco PP
'17 Mustang GT Conv
Old 01-21-2017, 11:52 AM
Roger 911's Avatar
OK. This is helpful. Thanks.
'72 911 3.2
'18 Mustang Eco PP
'17 Mustang GT Conv
Old 01-21-2017, 11:54 AM
Alarm.
By The way, do you have the factory alarm?
Gerry
1986 911 Targa.
Only in L.A.:
Old 01-21-2017, 12:31 PM
Roger 911's Avatar
Problem solved! A fuse wasn't fully seated in the engine compartment. How silly.
Roger
'72 911 3.2
'18 Mustang Eco PP
'17 Mustang GT Conv
Old 01-21-2017, 09:14 PM
BER BER is online now
BER's Avatar
Porsche Crest
Roger,
Just curious - do you recall which fuse was the issue?
Thanks.
Bruce
'12 Carrera S DFI
'84 911 Carrera
Old 01-22-2017, 05:19 AM
Roger 911's Avatar
Originally Posted by BER View Post
Roger,
Thanks.
My chassis is a '72, so I'm not sure if the fuses are the same as on a '84-'89. Having said that, I think it was the top fuse of the three that are back there. However, I did wiggle/rotate all three.
Roger
'72 911 3.2
'18 Mustang Eco PP
'17 Mustang GT Conv
Old 01-22-2017, 05:40 AM
BER's Avatar
Porsche Crest
Ok. No worries.
I also have 3 fuses in the engine compartment, along with two large relays. According to my owners manual, the top fuse is a 25 amp fuse for the Rear Window Defogger/Rear Window Wiper Return. But like you said, my fuse layout may be different.
Anyway, glad you are running again!
Bruce
'12 Carrera S DFI
'84 911 Carrera
Old 01-22-2017, 06:25 AM
