Tunnel Layout '70T
Hello. I'm putting my '70T back together and want to confirm that I'm running stuff through the tunnel correctly. Does this look right? So far I have:
Passenger side conduit:
* main harness
* starter cable
Passenger side wire clips:
* brake line
* speedo cable
Driver side conduit:
* fuel lines
Driver side clips:
* throttle linkage
'76 912E
'70 911T
Old 01-19-2017, 10:29 AM
Canyon Runner
70SC's Avatar
Porsche Crest Tunnel layout
Hope this helps
Old 01-19-2017, 01:50 PM
Thanks I've seen that (it's helpful but I think it's wrong, 8 & 9 are reversed).
I'm clear on where everything comes out of the tunnel, but am wondering what the factory routing was in the middle, for example what went through the two internal 'conduits' and what get's clipped into the welded-on tabs.
Jeff
'76 912E
'70 911T
Old 01-19-2017, 02:53 PM
Tim K's Avatar
As per my '69:
#9 is harness
#8 is Speedo
#6 is throttle
Old 01-19-2017, 03:01 PM
Yes, that is correct.
I'm still looking for info about the routing through the internal conduits.
If anyone has their shifter or e-brake out and can take a look into the tunnel and see what is clipped to the passenger side clips that would be helpful.
Jeff
'76 912E
'70 911T
Old 01-19-2017, 03:49 PM
Tim K's Avatar
These from my '73.5:
Sorry for the poor quality cell pics of ancient fotograffs...
Looks like the fuel lines remain secured at the top (plastic sleeves on tabs!) and the brake line runs along the bottom for the length of the tunnel.
With your ebrake assemby in place, the plastic hand throttle piece should align with the throttle rod. That should help determine where the three(?) plastic bushings go.
For memory, I thought the heater boxes and ebrake cables went straight through metal conduits to the ebrake assembly?
There was a ziptie on my '69 on the right hand side under the shifter cover keeping everything tight together so as not to rub on the coupler.
Hope that helps.
Tim K
Old 01-19-2017, 03:56 PM
seafeye's Avatar
Do these help?
What me speed?
Tim K:
Thanks, that's really helpful. You definitely have the fuel lines running through the conduit and then clamped to the top up by the shifter hole.
Then on the other side the brake line is clamped down by itself with the rubber protectors.
I wonder where the speedo cable went? Through the conduit or just lying there.
seafeye:
Yes I saw those, great views of what's going on in there, but it doesn't help with what routes through the conduits.
Jeff
'76 912E
'70 911T
Old 01-19-2017, 05:02 PM
Here's a photo of the passenger side of my '71T (sorry it's upside down-I can't figure our how to rotate it.) dho:
Old 01-19-2017, 06:18 PM
Cool, thanks for posting that. It's hard to see for sure but it looks like the speedo cable is going down under the conduit.
Jeff
'76 912E
'70 911T
Old 01-20-2017, 06:57 AM
Tim K's Avatar
This was bothering me. I usually have very good notes/pics during disassembly, but I could not find the routing info.
So I dug into my '70 parts car. I'm going to need this info too, eventually
The speedo cable (blue) passes under the starter cable and joins the brake line. Note the starter cable is zip tied to the ebrake line before joining the harness in the large conduit at the top of the tunnel.
The speedo cable is paired up with the brake line at each clip:
At ebrake:
At shifter:
I have other images if you need. Hope this helps.
Tim K
Old 01-21-2017, 10:46 PM
Oh heck yeah thanks Tim. I'll even add that zip tie, even though it seems pretty weird. 😝
It's funny, I took hundreds of pictures but you never have *quite* the one you need two years later with a bunch of new parts in your hands.
Jeff
Old 01-21-2017, 11:55 PM
