'84 Carrera faulty DME?
I have a '84 Carrera motor. Car has been sitting for about a month. Ran/started fine before it sat. Won't turn over now. Confirmed that when trying to start, there is no power being sent to either the starter solenoid, or the fuel pump. Swapped DME relay, no change. Originally thought it was faulty ignition switch, swapped that, no change. I'm thinking it might be the DME itself.
Any other suggestions? Roger
'72 911 3.2 '18 Mustang Eco PP '17 Mustang GT Conv |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Battery.
1. Battery cranking voltage/amp check. pm me as needed. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 01-21-2017 at 12:29 PM.. |
Diss Member
The DME doesn't power the starter solenoid so you have somewhere else to search. Obviously you need to have 12 volts from the battery cable at the starter but that would be hard to break.
I would start by checking at the starter switch to make sure it has voltage in and the starter circuit switches on when the key is turned.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
I guess the fuel pump won't run if the starter isn't turning the engine over, since the DME needs to see RPMs before it will power the pump. So the real question is just why am I not getting power to the yellow wire that activates the starter solenoid? I know the solenoid works, because I powered it directly and it does work. Just no power getting to that yellow wire.
Roger
Alarm.
By The way, do you have the factory alarm?
Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Problem solved! A fuse wasn't fully seated in the engine compartment. How silly.
Roger
Roger,
Just curious - do you recall which fuse was the issue? Thanks.
Bruce '12 Carrera S DFI '84 911 Carrera |
Roger
Ok. No worries.
I also have 3 fuses in the engine compartment, along with two large relays. According to my owners manual, the top fuse is a 25 amp fuse for the Rear Window Defogger/Rear Window Wiper Return. But like you said, my fuse layout may be different. Anyway, glad you are running again!
