Driver door locking problem
Driver side door panel is off so I can see what's happening. When door is already locked, turning key in door handle moves the latch inside door, unlocking door. Also microswitch seems to activate, causing similar action on passenger door.
However, when I turn key in opposite direction (to lock it again), I here microswitch activate and passenger door locks, but driver door does not. It looks like nothing is happening to flip the triangular piece on the latch in the opposite direction of when door was first unlocked. I haven't removed passenger door panel yet to compare action at that door to driver door.
Any clues?
Paul
'87 Carrera cab; '19 Ford Flex for the Dane and Lab; '17 Tacoma for truck stuff.
'96 993 cab (gone, oops); '82 SC (gone)
Old 01-22-2017, 02:18 PM
autojack's Avatar
I'm having a very similar problem on the passenger side. Subscribing to see what answers you get.
Old 01-22-2017, 02:38 PM
wrxnofx's Avatar
Verify the adjustable arm hasn't broken either of the plastic round ends. This is a pretty common problem. It is odd that the problem only occurs on locking, though.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 01-22-2017, 08:23 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Door lock.
Any clues?
What happens when you perform the same locking/unlocking sequence from
the passenger door?
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 01-23-2017, 09:35 AM
Paul, are you doing this with the driver's door open? If so, I don't think you can lock the driver's door unless it's closed.
Jeff
Old 01-23-2017, 10:09 AM
Jeff
Correct!
Gerry
1986 911 Targa.
Only in L.A.:
Old 01-23-2017, 10:58 AM
Jeff, only doing this with door closed
Paul
Old 01-23-2017, 05:25 PM
Gerry, I'm embarrassed to report that passenger door is not keyed properly so can't compare.
However, central locking button on console does not lock driver door. At this moment I can't recall if it unlocks it. Battery presently disconnected
Old 01-23-2017, 05:30 PM
twistoffat's Avatar
Hey Paul,
I had a similar problem and it turned out to be a failing micro switch. The problems started when the screw holding the cylinder in came loose. The doors started locking intermittently. After the problem got worse I noticed I couldnīt lock the doors anymore with the central locking button on the console. Eventually the screw came off totally and the cylinder popped out. I took the door card off and replaced the screw but no luck. I replaced the microswitch and hey presto everything was good to go. It was a bit of a bummer because I didnīt know if the problem was the loose cylinder of if the loose cylinder had somehow led to the microswitch problem.
Old 01-23-2017, 10:32 PM
WRXFONX, Looks like you diagnosed correctly. The plastic ball on top end of operating rod had broken apart and popped off the rod on door latch. I tried a temporary repair of ball to confirm but simple repair didn't hold. I guess I'll order two rods and replace on both doors.
I see our host has a plastic rod. I wonder how it compares to a Porsche replacement part.....
BTW, problem only occurs only when central locking is called upon. Unlocking affected door with key seems to be a direct mechanical action, and microswitch took care of central locking to unlock/lock opposite door. Locking the affected door seems to depend on central locking, so broken/disconnected rod prevented locking from taking place. I guess.
Paul
Old 01-24-2017, 09:10 AM
wrxnofx's Avatar
Awesome!
You'll need part #6 in this diagram:
Incidentally, the new one is a superseded design from the 964 and is no longer adjustable.
Check this post for a pic of it.
Old 01-24-2017, 09:59 AM
autojack's Avatar
Paul, this describes my problem exactly. Can you post a picture of the linkage where it is broken? This will help me when I go to repair mine. Thanks in advance!
Old 01-25-2017, 07:32 AM
Recreational User
porschenut's Avatar
For cars equipped with central locking, it is not possible to lock either door unless the microswitch is working. Both doors can be unlocked manually, but cannot be locked manually.
Old 01-25-2017, 07:35 AM
I replaced the operating rod today and voila! Everything is working again. Pictures (if they came across OK) show newly installed rod and top and bottom shots, plus old and new rods. First and last shots are upside down, so don't get confused.
I'll replace other door this weekend. While everything was open, I also adjusted window height successfully. Easy. It was too high and hitting upper seal of cab roof when closing door.
Paul
Old 01-26-2017, 03:13 PM
Diss Member
Quicksilver's Avatar
Don't bother to repair the rod. Just replace it because this is a rare case of a reasonable priced Porsche part!
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 01-27-2017, 09:45 AM
