The 9 Store
What hub/strut bearings do I need?
I started putting together a five lug front suspension for my 914. The hubs wouldn't slide onto the front struts so obviously I have the wrong inner bearings. I didn't realize there are two different spindle diameters. Both struts pictured are 3" 911. I can only find one part number for the inner bearing that corresponds to the strut with the smaller diameter spindle. What bearing should I be using? Thanks.
All used parts sold as is. |
Schleprock
It may just be a matter of a bearing that's not honed just right on the ID of the inner race. A local friend Ed (175k911) here on the forums had an issue some years ago with sketchy front wheel bearings.
New SKF inner front bearing doesn't fit on spindle....
Kevin L '86 Carrera "Larry" |
The 9 Store
These spindle sizes are completely different. Bearing fits on one but not the other. Not just a burr.
It's the strut that uses a pinch bolt, not a cotter pin.
All used parts sold as is. Last edited by mepstein; 01-25-2017 at 01:06 PM.. |
Bearing size........
Mark,
These are the old bearings I removed from the 3" spacing strut (Boge?) for my '78 SC. ![]() So what size bearing do you have now? Tony |
