-   -   Mich Leland Bushing Question (http://forums.pelicanparts.com/porsche-911-technical-forum/943903-mich-leland-bushing-question.html)
SC-Alfa 01-27-2017 11:47 AM
I've been trying to install the Leland bushing on my 81 today. However it's seems my factory bushing is intact. I can't see anyway to get this out without taking a hammer and punch to it, which I don't want to do. Is is an "if it ain't broke don't fix it" situation?
My motivation for doing this to begin with was some minor play in the steering.
http://forums.pelicanparts.com/uploa...1485546590.jpg
75 911s 01-27-2017 12:08 PM
Haven't done this job yet, but was looking at this thread
And is the yellow stuff between the metal part and the shaft the remnants of your old bushing? I think that has to be scraped out so the new bushing can go in there. The thin area of the ML bushing slides into that space.
Oh and assume you know about these:
http://forums.pelicanparts.com/porsche-911-technical-forum/480462-mitch-lelands-steering-wheel-bushing.html
petercory 01-27-2017 01:14 PM
Are you certain that the play is in the Steering Shaft rather than the Steering Column itself. If the play is in the Column, changing the bushing will NOT cure the problem. If the play is in the Column, simply remove the Tachometer and tighten the 2 column mounting bolts behind the dash at the bottom of the Tachometer cutout.
It seems that everyones reaction to Steering Column movement is that the bushing is the culprit, I fell for it also only to find that when I went to replace the bushing that it was fine, the movement was in the Column; I'll be happy to sell you my unused bushing for $20 plus $7 for 2 day domestic shipping.
SC-Alfa 01-27-2017 01:14 PM
Thanks for trying to help, but I've seen most of the old threads on this. Everyone else's factory bushing seems to have desintegrated making it easy to remove the pieces. My factory bushing appears to be made of metal and is intact. Can't see how to remove it.
SC-Alfa 01-27-2017 01:17 PM
It seems that everyones reaction to Steering Column movement is that the bushing is the culprit, I fell for it also only to find that when I went to replace the bushing that it was fine, the movement was in the Column; I'll be happy to sell you my unused bushing for $20 including domestic shipping.
Thanks. I'll check the column mounting bolts. I already have a bushing.
bugstrider 01-27-2017 01:26 PM
The posted link is not wanting to go through. Could you add the title so we may find it?
KTL 01-27-2017 03:08 PM
I bolded the above to point at what i'm thinking. I suspect the bushing that you have in there is the previously well intentioned "928 sleeve fix"
http://forums.pelicanparts.com/porsche-911-technical-forum/681046-steering-wheel-moves-up-down.html
I think years later people have started to find the 928 sleeve can cut into the steering shaft and you end up with a problem similar to the original plastic sleeve
Geronimo '74 01-27-2017 03:38 PM
Mitch's bushing is one example of " if it ain't broke, replace it anyway.
Original bushings are getting old, replacing them is cheap and easy.
It is sorta like pre-emptive maintenance.
I'm happy with mine.
Would recommend!...
Contact mitch and get your issue fixed.
Do it.
dlagerstrom 01-27-2017 03:54 PM
Yup. Looks like the 928 fix. I believe the only way to remove it is to push the shaft out which must be done from the trunk after taking out the circlip on the shaft at the lower bearing. This would be lots of work. I just did it but have a completely stripped tub, so it was easy. Good luck.
sugarwood 01-27-2017 07:49 PM
Why would you want to remove the 928 fix?
Does that splined shaft move like this?
If not, the problem lies elsewhere.
<iframe width="560" height="315" src="https://www.youtube.com/embed/MWqsp3-wj_Y" frameborder="0" allowfullscreen></iframe>
SC-Alfa 01-28-2017 06:38 AM
Thanks guys. I think I do indeed have "the 928 fix".
I think I will leave well enough alone for now.
