David 23's Avatar
AC delete weight savings in 911SC?
Curious what the actual weight saving is by removing the AC system from a 911 SC, and what components are typically removed? I assume one would still have heat, defrost and blown ambient air?
1979 911SC 3.2 SS Custom Backdate Hot Rod
1972 911T, 2.7RS Spec
Beck 904 Carrera GTS /3.6
2023. Macan
Previously owned several 911 models since 1975.
Old 02-01-2017, 06:57 PM
Banned but not out, yet..
RSBob's Avatar
AC delete will not affect heat, defrost or fresh air. I removed all of mine other than the cabin control wires. Don't have an exact weight savings. But my guess is around 60 lbs but others will have an exact figure
Also removed center console since it was more dead weight
Old 02-01-2017, 07:17 PM
This is a great thread on weight loss:
438 lbs gone in 5 days - My Build Story
This shortcut will take you to the page look for post 99...where he summarizes the AC weight removal.
Old 02-01-2017, 10:15 PM
Kraftwerk's Avatar
You can also remove rear seat belts and seat backs / rear parcel shelf.. rear speakers, all easily done & reversed, ac delete is a bit more involved but worth approx. 60LBS. & is noticeable...
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 02-02-2017, 10:19 AM
Rescuer of old cars
Arne2's Avatar
The bulk of that weight is in the compressor, compressor bracket and the hoses. The condensers don't weigh that much, but the rear unit is so easy to remove that I'd do it. The receiver/dryer comes off with the hoses. If you remove the front condenser, condenser blower and evaporator in the smuggler's box, you will need to figure a way to seal or block the various body openings.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 02-02-2017, 10:57 AM
Even if you remove everything else, keep the blower in the smuggler box. It will blow air directly on you. The fresh air system in an air cooled 911 is pretty much useless.
The AC, fresh air and heater are three separate systems and can be run one at a time or in any combination and even all on at once.
The AC blower will blow ambient air temp but it will blow it right at you. I run my AC without the compressor running at an autocross. It helps a lot. My AC works great and I love it on the way home from the track.
Old 02-02-2017, 12:30 PM
Counterclockwise?
Does anyone bother covering up the hole from the compressor bracket?
Rod
1986 Carrera
2001 996TT
Old 02-02-2017, 12:46 PM
I would keep the AC. A 2006 Subaru Forester 2.5 XTE with a Mom and her kids will still pass you. Just having fun. But it's true. Guys want to make their 911 as light as possible so it is almost as fast as modern cars.
Old 02-02-2017, 02:00 PM
I removed mine when I had my 83SC because it didn't work for crap any way, and my car was black on black. I also did a heat backdate which cleaned up the engine bay nicely.
Im not much of an AC fan in cars unless it's ungodly hot. Usually open windows are enough to cool me down. I say do it.
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 02-02-2017, 02:14 PM
Jonny H's Avatar
We'll be showing our lightweight electric A/C at the LA Lit show on March 4th. Weight is 30lbs, about half the orignal A/C weight, plus it is all up front.
www.classicretrofit.com
Old 02-02-2017, 02:32 PM
I did with a plate.
Old 02-02-2017, 05:17 PM
oops here is the picture of the plate I made:
Old 02-02-2017, 05:25 PM
More Likeable IRL
juanbenae's Avatar
weight aside it really clears up the motor compartment a ton.
Old 02-02-2017, 05:32 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
BUTT, will it hang icicles on yer nadz in Texass heat, Jonny; like my heavy, and heavily modified original system does?!?!
Plus, and to piggyback on what NastyNick said, the weight of the a/c system, and the non-cluttered engine compartment are only concerns for those who have 911s with weak, non-turbo powaaa plants and wimpy, non-Turbo brakes (not a concern of mine, in other words!!!), and it barely helps at all anyway in terms of outright acceleration and deceleration (aka- soccer moms will still whip dat' non-turbo, 911 azz)!
Old 02-02-2017, 05:38 PM
RSBob's Avatar
After pulling the AC crappola, I backdated the rear windows to pop-outs and get good airflow through the cabin. Bought the windows from a fellow board member and got the hardware from a bunch of sources.
Old 02-02-2017, 06:13 PM
T77911S's Avatar
i agree. its not a race car. I know when I had my 77s my brother removed all the AC before I got it. I wished he had not as I started to put it all back together but sold it before I ever did.
in the process of getting the 930 AC working. just need rear condenser. sure it looks better without it and even much easier to work on. and even though I don't drive it in the dead of summer I would like some AC if we need it on a trip.
these cars are going up in value, AC can add a lot.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 02-03-2017, 02:54 AM
Counterclockwise?
I found when I removed my hose there was a lot of gravel stuck up there.
Probably a couple of pounds.
Rod
1986 Carrera
2001 996TT
Old 02-03-2017, 05:26 AM
VFR750's Avatar
~57 lbs
That was the weight of the components I removed from my SC.
Old 02-03-2017, 08:25 AM
French Import
zippy_gg's Avatar
Reduce your intake from 4 cheeseburgers a week to just 1, delete all soda from your diet , and you will feel your car performance improve gradually, over time...
I can't emphasize enough the need to reduce the weight in your car!
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 02-03-2017, 12:15 PM
RSBob's Avatar
Pulled 140 lbs out of mine which made a noticeable improvement in acceleration. But the rear end came up so high, had to re-lower it, align and corner balance. But who-hooo, cheap power!
Old 02-03-2017, 08:26 PM
