SSI Question
On my stock 83' 911 SC, I am going to be replacing my stock heater boxes with the SSI's and the stock muffler with a Dansk 2 in 1 out sport muffler. With this new set up, is the cat automatically eliminated? Or do I need something else?
Old 03-10-2017, 02:54 PM
Jameel's Avatar
I'm in the process of doing the same with my rebuild and have been reading up. Yes, the cat is deleted entirely.
Old 03-10-2017, 02:55 PM
pete3799's Avatar
You will need different oil lines.
Pete
79 911SC RoW
Old 03-10-2017, 03:15 PM
Bill Verburg's Avatar
Yes, the cat is eliminated
you also need to replace the oil lines w/ the version from '1974
You can see the old style oil-line that goes under the trans here, you will also need to rerun the heat
here you can see ann SSi install, oil line is visible near the flywheel end of the block and heat behind the mufffler. Here cats were used on the muffler outlets, these aftermarket cats are only required where legal constraints are enforced.
Bill Verburg
Old 03-10-2017, 04:22 PM
Thanks to all for the feedback. I did purchase the additional oil lines as recommended by Pelican. I am looking forward to better sound & performance.
Old 03-10-2017, 07:04 PM
how are you going to handle heat?
Old 03-11-2017, 06:33 AM
evan9eleven's Avatar
Slightly OT: Bill, interesting that the cats are after the muffler just before the outlets. I thought that a cat would need to be placed as far as possible upstream in order to get to temperature quickly and be effective. Just curious
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 03-11-2017, 01:52 PM
Not sure....What am I missing? I thought the SSI was basically a pre-74 arrangement for heat for the cabin with better flow to the tailpipe. In other words, I thought the SSI provided heat in lieu of the stock heater boxes (in addition to better performance).
Am I mistaken?
Old 03-11-2017, 05:58 PM
SSI provide heat.
Old 03-11-2017, 06:54 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Not sure....What am I missing?...
Just do a backdated heat, SSI Heat Option
Who Will Live... Will See
Old 03-11-2017, 07:03 PM
To PO: I just backdated my '82SC and happy to answer any questions. PM me if you have any.
Old 03-11-2017, 08:29 PM
Vintage Owner
Jack Stands's Avatar
You'll love the SSIs! The heat output is great and the system is much simpler than the fan assisted later systems. It takes the 911 engine back to the way the engineers originally designed it before the EPA mandated changes. I like clean air, but with the amount most vintage Porsche's are driven, I don't believe they contribute significantly to degradation of air quality. Then again, I live under the O'Hare Airport glide paths!
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 03-11-2017, 08:57 PM
