gliding_serpent's Avatar
How much can i lower seat rails?
Finally geting the fuel lines out and seat rails shortened. The goal is one inch lower for use with aftermarket sliders with my race seats, while still allowing me to use my original seats now and then.
With the stock seats, in a 3.2, how much can you lower the seat rails without interferance with the seat (stock sliders) and transmission tunnel when the seat is set back? I knew this answer a year ago, but now i forget, and research here suggests 1 inch, but memory says 3/4 in the rear.
A memory jog would be appreceated.
1997 BMW M3 (race car) with S54 engine swap "The Rocket"
1984 Porsche 911 3.4 Carrera
1973 BMW 2002Tii
2016 Ford Focus RS
Old 03-10-2017, 05:41 PM
Cars and Cappuccino
tdw28210's Avatar
I am seriously considering removing my seats rails from the tub, turning them over and swapping them from side to side. Based on the angle, I think I may pick up an inch or so of headroom. Trying to figure out why it won't work. Haven't thought of a reason yet, but I haven't started cutting the welds either.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 03-11-2017, 05:56 AM
Diss Member
Quicksilver's Avatar
Seeing that you are using race seats there isn't really a point to lowering the rails. Race seats should be side mounts and it is no big deal mounting the seat below the seat rails. (I've got the bottom of my Cobra mounted about an inch lower than the rails.)
If your "race seats" are bottom mount...
That isn't a great idea. A bottom mount is loading the mounting points in tension and it is WAY easier to pull the mounts out of the composite. A side mount is mounted in shear which is MUCH better plus if it fails it is likely to tear along through the composite making a slot instead of pulling free.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 03-11-2017, 07:43 AM
Irrationally exuberant
ChrisBennet's Avatar
My car is in storage so I can't post a picture, but I made a bracket that bolts to the bottom of and hangs below, the stock "platform". My sliders bolt to that and my seat brackets (custom made for my Cobra seats, side mount). The end result is a race seat I can slide forward & back and if I ever want to go back to stock seats I can just unbolt the "mounts from underneath" bracket and it's back to the way it came from the factory.
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-11-2017, 02:24 PM
You are correct, except that my side mount seats don't fit between the rails. That was the first thing i checked. I like to avoid headache whenever possible. I need to cut the rails to achieve my goals.
How did you make it work? If i remember correctly, narrowing the rails to make my seat fit between them compromised the holes for the oem sliders.
1973 BMW 2002Tii
2016 Ford Focus RS
Old 03-11-2017, 09:20 PM
