Cool
Originally posted by EWPurdy
The problem first arose after the carb conversion.
I don't have hard experience with carbs on the 911.. plenty around here do.. so better to bow out on that one..
if the tach takes a sharp dive at this miss, then definately ignition problem somewhere...........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-21-2003, 05:52 PM
pwd72s's Avatar
I'm just a neophyte, and my car is injected. But if I were to be given the job of designing a float level window in a carb? I'd think the level should be dead in the middle of the window, with everything off. Then a dead level, middle of the road level should be right. Right? Here I go again...thinking things should be logical. One needs only to observe the current and past political scene to know that isn't so...
Old 01-21-2003, 06:13 PM
Cool
Hey Eric .. if you want to get logical I have the 3 soft covered Weber books/at least, and can scan anything you want.. the scanner is a new toy and I can't shrink it and still be legiable.. so I'll have to do a direct e-mail.. not confirming that being logical will solve the issue
Hey Paul .. Libya is now chairman of the UN Human Rights Commission.. maybe the UN figures it's about time for truth in advertising... screw the UN, that's logical.....
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-21-2003, 06:54 PM
Gasoline User
1974carrera's Avatar
Eric, what are you using for a fuel pump and fuel presure regulator with the PMO's? In the pic of your engine, is that the pressure regulator immediately to the right of the pressure gauge?
Bob V
1974 911 Carrera coupe Grand-Prix-weiß
1977 930 turbo Carrera coupe Hellgelb
2018 Cayenne turbo Schwarz
2019 911 GT3 RS Schwarz
Old 01-21-2003, 07:02 PM
Thanks for the offer
Ron,
I've got one of the Weber books myself and as each day passes I'm learning more and more. The problem is that the PMO is a little different here and there and that seems to be where it counts. I had the carbs apart yesterday and I should have taken a few pics but I was hot on the trail of those floats and didn't get any pics. Wish I had taken the main jets/emulsion tubes/air correctors out while I was at it. Just couldn't imagine they're plugged already.
More info is always appreciated but please don't slave away over the scanner to send a bunch of files. If you see something particularly insightful, I'd love to see it. I'm at:
ericnbel@2fords.net
No dip in the tach btw- that's a sure giveaway for the ignition. I only wish it was that easy.
Break...Break....
Paul, the fuel level with the floats properly adjusted and working 4.0 are dead on the sandblasted dot in the center of the view window. Mine aren't quite perfect with the internal specs of the floats pretty damn close to PMO's requirements. I may tweek some more to get them dead on.
Eric Purdy
Old 01-21-2003, 07:07 PM
Bob,
Pump is stock CIS pump with a Mallory 3-20 psi bypass regulator.
Eric Purdy
Old 01-21-2003, 07:14 PM
BTW here's the book I'm using...
Eric Purdy
Old 01-21-2003, 07:34 PM
pwd72s's Avatar
[QUOTE]Originally posted by RoninLB
You're kidding? You're NOT kidding? What's next? A Ted Kennedy school of driving????
Old 01-21-2003, 07:52 PM
Cool
Hey Eric .. that's the Braden book.. I have more if you need greater/maybe info on a topic..
-but I kinda think, if your coil checks out, that the miss may be a pop.. so if it's not a lean adjustment on that carb, then the external gaskets to the head may be leaking.. just a thought..
- but the air screw on #2 ????
-and do you notice the "miss" thru the carb? or thru the exhaust?
-does/did any spark plug look hot, as from a lean condition?
I bet if a 911 carbhead reads all this the prob will be over...
and Paul .. Not Kidding
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-21-2003, 08:32 PM
...do you notice the "miss" thru the carb? or thru the exhaust?
Not sure as I can only get this to happen under load while accelerating. If I rev the car in the garage it runs fine up to redline.
...does/did any spark plug look hot, as from a lean condition?
Plugs all looked uniform and a bit sooty. Switched up to the next hotter heat range plugs.
I bet if a 911 carbhead reads all this the prob will be over... Amen! Calling all carbheads.
Thanks to all for their interest and help.
Eric Purdy
Old 01-22-2003, 05:02 AM
Cool
[B
Thanks to all for their interest and help. [/B]
the load info is meaningful.. if me I'd go after points and coil, then the box.. because you don't have any resistors in plug wires.. I hate Beru connectors
"Thanks to all for their interest and help".... it'll cost you on payback one of these days, LOL................Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-22-2003, 06:35 AM
You might check that you have a good seal between the spacer blocks and the base of the intake manifold for starters. All idle screws should be relative as a baseline. As for the miss - the float bowls need to be PERFECT. Your CIS pump might be overkill, as the carbs only need 1/3 of the pressure your pump is putting out. If your floats continue to stay flooded to the top- nothing good will come of this condition. Too much gas and it will have no where to go but out onto your HOT engine= fire! Talk to Rennsport Systems,TRE,COX Motorsports etc - all their customers have race cars with these carbs - your floats need to be persuaded within range to get the fuel level to the sand dot on the inspection window of the carb.
Good luck.
Old 01-22-2003, 06:50 AM
Progress!
My suspicions about the veracity of the fuel pressure gauge I had seem to be founded. I turned the regulator down until the indicated pressure was 2 psi and, low and behold, the float levels droped to the proper location on the sandblasted dot. I knew from previous reading that these gauges are inherently inaccurate especially when reading near the extremes. I'd like to get an electric sender to wire a gauge into the cockpit so I can monitor it from there with no hazard of fire. Any suggestions. At any rate I'll find a replacement in the meantime.
Alas, the miss is still there and I was able to reproduce it in the garage. It's not nearly as noticible just a some popping in the exhaust (not out the stacks) when I get up to about 4K RPM and beyond. While driving the effect is much more pronounced. I'm going to go through and double check the balance on all throats at 4K RPM and above to makesure I'm not missing something easy here.
Ron,
BTW, got the PDF files - thanks mucho!
Eric Purdy
Old 01-22-2003, 02:57 PM
Next step for you is to check the pump volumes with the vial that was included with your carb purchase. It is VERY important that each cylinder is the same. Do you have a carb synch tool?? Are you positive that each barrel is pulling the same amount of air? You are on the right path and most likely will be able to dial out the miss you are speaking about. Good luck.
Jim
Old 01-23-2003, 05:14 AM
ttweed's Avatar
Just found out that PMO has a website now. Go to PMO site and look under "support".
When I had a "rising idle" problem with mine, it was the distributor not retarding the spark enough at idle.
Good luck,
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 01-23-2003, 08:08 AM
Kolibri
blackbird225's Avatar
What does PMO statnd for ( yes I'm new )
Michael
1942 VW Kübelwagen
1940 Zündapp KS 600
1941 Zündapp KS 750
1975 Volvo C303 TGBII
1967 Honda S90, 1975 CB550
Old 10-01-2003, 11:56 AM
Wonder who's muffler is on the PMO site....
Warren & Ron, may you rest in Peace.
Old 10-01-2003, 12:43 PM
ttweed's Avatar
That looks like a Dansk.
TT
Tom Tweed
R Gruppe #232
Old 10-01-2003, 01:27 PM
Porsche Mail Order...PMO.
Eric Purdy
Old 10-01-2003, 05:47 PM
what was the answer to this mystery ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-24-2005, 08:39 PM
